Intense Stage 3 Reveiw
Originally Posted by retrop
Edit: vid works on PC not mac...
That is awesome. The boost gauge went from about 5psi to 18-20psi in no time. Awesome! I bet that thing pulls hard
Originally Posted by sneaky
I think Rob said it needed a smaller belt to adjust for the smaller pulley. Too much belt.
Have any idea where he found a smaller double ribbed belt? Would be a lot cheaper then a tensioner.
I take the mac part back it is a surfari thing....i refuse to use IE and have been too lazy to download anything else...
Firefox is awesome. That's what I use. It's fast
Originally Posted by distillion
hows yer clutch holdin up?
Like any other manual trans car out there, until you hook the power up, there is not much stress on it thru spinning tires
I will believe it when I see it. I dont think you beat an evo, since you cant drive and the EVO runs 12sec. The most power you would get from the above is about 30hp thats about a 14sec in a quarter.. The GM stage 2 kit is 37hp and has a PCM upgrade. I could be wrong but I dobt it.
The price seems to cheep. Just remember you get what you pay for. The fuel injectors alone for mine are about $400. Plus with out a PCM upgrade your computer will start shutting down at about 5'000rpm. It will say engine power reduced then start running on 2cyl's. The PCM is way to tochey.
