intense stage IV + V
Old Jun 15, 2006 | 06:10 AM
cavy9psi's Avatar
anyone know how these intense stages IV + V's are??? 17psi=stage IV and 19psi=stage V
isnt that outa the chargers efficiancy range? seems like good power though if it is good anyone have it?
Old Jun 15, 2006 | 10:44 AM
BooSSted's Avatar
I have Stage 4, it's amazing. The car runs smoother and quieter than stock. But when you hit the gas it unleashes a monster inside, haha
Old Jun 15, 2006 | 10:47 AM
CTCOBALTSSS's Avatar
I am very curious as to what the Eaton's redline is too. Anyone know the real answer?
Old Jun 15, 2006 | 10:54 AM
WSFrazier's Avatar
^^^ Curious about the same. I want the 2.5 pulley but don't know what it does over time, this is my daily driver.
Old Jun 15, 2006 | 10:59 AM
cybcow's Avatar
Get the stage 4 with 2.5" pulley (19psi). This is really the way to go. Otherwise I can't tell you until Monday. But otherwise the old Stage 3 really put the SS in my cobalt. Don't think about it, just buy it
Old Jun 15, 2006 | 11:01 AM
CobaltBurst's Avatar
yea i will have my 2.5" pulley for my stage 4 from intense next week sometime and i will have it dynoed 7-1-06 ill let you know, when you gun this car... it is a monster..
Old Jun 15, 2006 | 11:43 AM
player_1's Avatar
the M62 starts to loose efficieance after 14000RPM
Old Jun 15, 2006 | 11:46 AM
djt81185's Avatar
its actualy 16k for the gen v
Old Jun 15, 2006 | 12:09 PM
WSFrazier's Avatar
What is the RPM with the 2.5 pulley at max?
Old Jun 15, 2006 | 12:24 PM
Bad06SS's Avatar
Exactly. Plus, the ported supercharger helps with the efficiency.
Old Jun 15, 2006 | 01:30 PM
cavy9psi's Avatar
so stage 4 or 5 which should i do and is it worth it?????
Old Jun 15, 2006 | 01:34 PM
player_1's Avatar
that's right, although the actual safe running limit of the charger is 16k it begins to produce less power after 14k do to excessive gain in heat
Old Jun 15, 2006 | 01:35 PM
the only difference between 4 and 5 is a smaller pulley (you can ask for the 2.5 instead of the 2.7 in stage 4) and the ported blower. but if you want yours back its going to take 3-4 weeks unless you want a different one already ported. so im skipping that.
Old Jun 15, 2006 | 01:36 PM
Tomtwtwtw's Avatar
In case you missed it in the other thread, the blower is spinning at about 16800 rpm at 7k w/2.5".
9mpg, go go go!
Old Jun 15, 2006 | 01:38 PM
player_1's Avatar
go with stage 4
if you get the charger ported, you'll need the intake manifold opened up to receive maximum benefits from the ported charger
Old Jun 16, 2006 | 09:03 PM
cavy9psi's Avatar
yea but if i dont get the 5 with the ported charger.....id prolly lose some power...so i should just send my core after i get a charger from them with the stage 5....right?
Old Jun 16, 2006 | 09:17 PM
Matty's Avatar
I am purely speculating, but I would be willing to bet the PCM flash between stage 4 and 5 will be different to allow for the added boost the smaller pulley for stage 5.
Old Jun 16, 2006 | 09:27 PM
FAST06SS's Avatar
We spoke with eaton engineers about that exact topic and thier comment was as follows,
"yes, you are spinning it pretty hard but at such short intervals, nothing will be compomised. Now if you go run extended high rpm operation like a road course or top speed race at a continuous high rpm, then problems will happen."
Hope that helps
Old Jun 18, 2006 | 07:55 PM
cavy9psi's Avatar
as far as the guys/girls with the stage 5 or running the 19psi however you achived it....is the engine good for the power? i know id need a clutch...
1.ive come across a thread or 2 about lean codes...anyone getting that code or any code with the stage 4 or 5 if so what is it.
2. MAF translator i noticed didnt come with this kit...not needed cuz the PCM upgrade or would it be a good idea to get?
3. 1 favor id love from someone or a few people is maybe a video clip of a second gear drive by WOT but then again i wont be picky i just wanna kind of see the power before i buy....it would be great if someone could thanks in advanced...everyones so helpful its greatly appreciated buy us newbies...
4. as far as the dyno intese shows do they have intake and exhaust on the cars? or thats some more added power to the numbers
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
