interCEPTOR GAUGE scanner
Old Mar 3, 2010 | 03:43 PM
Winkdogydog101's Avatar
hey just need to know 2 things
there is iat 1 and 2 just wondering which ones what and which one i want
then there is knock 1 2 and 3 again which one do i need
THANKS GUYS
Old Mar 3, 2010 | 03:57 PM
Zach06CobaltSC's Avatar
You need to monitor your iat2's, and your kr. There should only be 1 kr setting if it's setup correctly.
Old Mar 3, 2010 | 09:19 PM
ok
ok i read the how twos but i got a question i have the how to's but i cant see the photos do you need to splice the red power wire to the boost gauge or no? just wondering
also it doesnt tell you how to adjust it and go through everything very well someone who could help me with this would help out a ton
ok i have probelms now if it is pluged in the obd2 it wont shut off and because i wired it to the boost all my gauges are on how do i make it shut it off im looking on the manual on line but it doesnt help me that much
Help please someone i really need this answered or im going to start shooting my car
Last edited by Winkdogydog101; Mar 3, 2010 at 09:19 PM. Reason: Automerged Doublepost
Old Mar 3, 2010 | 09:35 PM
all4glh's Avatar
I didn't think you needed to hook into anything for power with the SS/SC's, just plug into the OBDII and call it a day. Try disconnecting your external power from your boost gauge and see if it has power still. If you still need power, could always do an add-a-fuse with a switched source in your fuse block.
Old Mar 3, 2010 | 09:36 PM
i thought u needed the red power pluged in? no ok ill go check it out but when i turn the car off it wont turn off
Old Mar 3, 2010 | 09:39 PM
all4glh's Avatar
Just try disconnecting your external power source (from your boost gauge) and see if your interceptor still powers up. If so, fixed. If not, do an add-a-fuse to a switched source in your fuse block instead of what you're currently doing.
Jan 12, 2016 12:01 AM
agentirons
Oct 16, 2015 02:11 AM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Sep 27, 2015 08:53 PM
