Interceptor Trouble
Old Feb 23, 2009 | 02:41 PM
roadkillj_16's Avatar
Interceptor Trouble
I went recently and finally got my car tuned it took a minute cause a fuse blew the one to OODDII port. Well once that was finished everything was great except win I plugged my guage back in. The water pumped turned on and the guage did too with the keys not in. And if I leave the guage plugged in when the engine running and turn it off the engine will stay running. I think another fuse is blown or something. Does anyone have any advice about what fuses to look at?
Old Feb 23, 2009 | 06:18 PM
flash13brandon's Avatar
Not a fuse. Take off the resistor on the back of the interceptor. It will fix your problem I promise.
Old Feb 24, 2009 | 03:08 PM
ok that worked but now I have to still plug it in to work I guess I'll just have to re-wire it thanks.
Old Feb 24, 2009 | 03:12 PM
M88ArRamadi's Avatar
you have to remove the jumper/resistor or what ever that thing in the back is(liike brandon said). You'll still have to tap into a power supply and plug it into the OBDII post....should solve all your problems
Old Feb 24, 2009 | 03:36 PM
any recomendation on what I should hook the power into cause what I had tried started causing the problem after I got it tuned.
Old Feb 24, 2009 | 03:41 PM
If it was a 5v the I tapped into my boost gauge....if it's 12v I ran a seperate wire to fuse box. I'v put so much into my car I don't remember which is which anymore
Old Feb 24, 2009 | 03:52 PM
thanks I'll give that a try. I'll get back with you about it. But if you do remeber give me a shout.
Old Feb 24, 2009 | 03:56 PM
oops.....I have the manual right here (I'm selling mine and have all the stuff for it right here) ......
red wire is a 12v switched power. it's the middle of the 3-wire harness.
Old Feb 24, 2009 | 04:00 PM
so anything that takes 12v or more? What does the boost gauge take? I hook mine into that and now it is no good.
Old Feb 24, 2009 | 04:15 PM
boost gauge is 5v...you need to hook yours up to a 12v switchable. means a 12v power supply that turns on when your car turns on...ALSO make sure you put a fuse in there
you are going to need a multimeter and verify 12v switchable power.
Last edited by M88ArRamadi; Feb 24, 2009 at 04:15 PM. Reason: Automerged Doublepost
Old Feb 24, 2009 | 04:16 PM
thanks I definitely try that. just any 12v spot that turns on when the car turns on and I should be good right? as long as I put a switch & fuse in it?
Old Feb 24, 2009 | 05:02 PM
black07ssc's Avatar
I tied my red power wire into the pink power for the boost gauge to power mine up and no issues with it. i'm not sure about the 5v thing being posted here as thats probably the signal to the boost gauge. Do a search on interceptor install should help you out.
Old Feb 24, 2009 | 05:05 PM
mine was orginally hooked up into the boost gauge and after the tune it been doin this. I think I am going to switch it into directly in the back of the ciggarett lighter. thanks for the help though
Old Feb 24, 2009 | 05:17 PM
black07ssc's Avatar
If i remember correctly theres a jumper in these gauges to that could be causing you grief.
Bluelightning
Nov 11, 2015 02:41 PM
Supercharged06SS
Oct 5, 2015 09:13 PM
nathan112i
Sep 30, 2015 07:12 PM
bustaSS
Sep 3, 2015 09:33 PM
