Intercooler
I have been looking for an intercooler for my 2005 cobalt SS and have not came across one on any website. I was looking through http://cobalt-addiction.com/rides.htm and I clicked on "rides", I looked at the girls car that is shown on it. I noticed that she had an intercooler or something that appeared to be an intercooler. I have been trying to find an intercooler for my car, I was not sure if they produced intercoolers for supercharged engines but it appears a company does. If you know of any intercoolers or can identify what that is in the pictures and tell me I would be very appreciative and interested in purchasing it, if you can find where one is located.
Well i was going to pull one of those "Silly rabbit, our cars have "intercoolers" stock" posts but after looking at the pictures I see your point. It's possible that its a heat exhanger that closer to the front bumper and not sandwiched between the radiator and condensor as our stock ones are. I can't seem to get a good look at it so I can't really answer you but I'm curious now as well.
NOOOOOOO........PUTTING A FMIC DOESN'T DO ANYTHING FOR THE LAST TIME! EITHER THAT ONE IS FAKE OR JUST A WASTE OF SPACE!!!
If you want to do ANYTHING that looks like FMIC, you need a heat exchanger
https://www.cobaltss.net/gallery/bro...=3&userid=5323
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/lfp-cobra-he-somewhat-installed-pics-26705/
Originally Posted by Ljavy17
where r we going to be able to buy this heat exchanges.
Originally Posted by Sicklyscott
cost?
The one for the Cobalt I think is a little smaller so I have no idea where to guess.
Originally Posted by vandy0419
No clue...you can contact Mark at the number listed on the website above.
The Cobalt SS HE will be out middle to end of august. I am prototyping and am still measuring everything out from Mark. Our shop in Aurora, Illinois will be a dealer of the HE's for the Redline and the Cobalt SS!!!
after having some questions about using an actual air-to-air intercooler in conjunction with the stock setup, i think we're going to try it this weekend on my car. my friend happens to have an extra intercooler, we'r enot sure if it will fit, and we will probably end up using dryer hose as a temporary hookup for the intake.
we'll get some pics and video of it... i know alot of people say it won't work, but hell we got plenty of zipties and an intercooler.... no reason not to try it
so the fact that when my iat1 temps are about ten degrees cooler, my iat2 temps are about 10 degrees cooler, means nothing huh?
i know it's not going to supercool the air, but what if it drops the iat2's even 30 degrees? the stock setup on a third gear pull ran up to 164 degrees.. there's no way it can do any worse
It just dosn't make sennce!! seriously!! just stop and think for a second...
You are pulling in ambiant air, and trying to cool it with.. ambaint air.
It dosn't work!! It's like trying to cool off one hand, with your other that is the same temp. All your going to do as add a restriction.. bad idea people!
Also, tell me what the point is of cooling air a simple ten degrees BEFORE the s/c? It is after the s/c where the temps need dropped. My goal is to get the IAT2 below the IAT1, which will hopefully be possible with the LFP HE, LFP Ice Box with dry ice and DEI Chiller Charger.
Also, how is cooling the IAT1 ten degrees going to cool the IAT2 down 30 degrees? You're being serious? It does nothing, plain and simple. For the air to have to pass through a intercooler, you are causing the airflow to be distorted...we're not turbo charged...the s/c will suck in the air, so why slow it down from getting there? Seriously, the whole point of an intake system in general is a smooth flowing system to get the air into the s/c without anything distorting it.
uhh read it again, i said when the ambient air is ten degrees cooler, so is the iat2's. if you know anyone with an intercooler and it only cools their intake temps down ten degrees, they might want to get someone to take a look at it for them
yeah it's a horrible idea and no one should ever try it!!!
i'll be posting results this weekend
Go ahead and use a intercooler and let us know your results of the IAT2 in the same conditions, drive for a while on the highway, then hook up your intercooler and do it again for same amount of time in the same conditions and report back. While I'll hook something up in the same location in which I'll be cooling the IAT2s around 30 degrees...
i will explain in due time why i have an intercooler...some of you already know though, those of you from LI who have been to the shop and got a chance to talk to kenny about the "project" know its not just there for looks or to waste space.
