Intercooler Pump failed
Old Mar 16, 2010 | 07:49 PM
johnladow07's Avatar
It seems that my intercooler pump is bad. Already did a search on the forum, but I have a few questions before I get the replacement. Are the lightning/cobra intercooler pumps identicle?
This is the part number I plan on ordering: Bosch PCA 12V , 0392022002.
I want to make sure it is identical to the stock lsj pump, so I can reuse the hoses and whatnot.
Thanks
John
Old Mar 16, 2010 | 07:59 PM
qwikredline's Avatar
one and the same...OTTP sell them for 100 bux...
Old Mar 16, 2010 | 08:01 PM
Do I need a harness? or just the replacement pump? Im seeing some on ebay with a harness.
Old Mar 16, 2010 | 08:26 PM
Just the pump ;unless you screw the clip upand yank on the harness in the install. Its a little spring clip, take a small screw driver and prise gently to remove it and release the connector.
The pump itself requires two bolts removed, use a 10 mm socket ( afair)and them transfer the rubber sleeve to the new pump and reinstall dont over/under tighten the pump bracket. I cant remember the torque value safest thing to do is use a 1/4 drive ratchet hard to crank it too tight that way....good luck.
The pump itself requires two bolts removed, use a 10 mm socket ( afair)and them transfer the rubber sleeve to the new pump and reinstall dont over/under tighten the pump bracket. I can remember the torque safest thing to do is use a 1/4 drive ratchet hard to crank it too tight that way....good luck.
Last edited by qwikredline; Mar 16, 2010 at 08:26 PM. Reason: Automerged Doublepost
Old Mar 16, 2010 | 11:26 PM
Joe Schulte's Avatar
$99 free shipping-
http://www.yatesperformance.com/en6400.html
Where I got mine, quite pleased.
Also have a local/forum member here doing rebuilds, guy has tons of experience, don't know his charges but I already know a couple people running them with no issues.
Old Mar 16, 2010 | 11:29 PM
Dead Zen's Avatar
did ya hit it with a hammer. brings em back for a while supposedly
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
