Intercooler pump option?
Old Jul 14, 2009 | 10:28 AM
phatnackySS's Avatar
cant find any specs on it, but maybe you guys can help.
half the price of the unit on our cars but maybe just as good maybe better?
its made by Bosch and looks to be similar in design. the only thing would be to make an adapter for the plug, but that's easy enough.
http://www.autopartsworld.com/merced...pump/1992.html
Old Jul 14, 2009 | 12:03 PM
red06SC's Avatar
I thought those were the same pumps as ours....
If they are, thats a damn good price.
Old Jul 14, 2009 | 12:29 PM
turns out it is the intercooer pump for the AMG SLK32 ...if its good enough for Mercedes its good enough for me. i think im gonna order one or 2 lol
Old Jul 14, 2009 | 04:45 PM
Maven's Avatar
All the same **** afaik, the ford guys use the MB pumps, the MB guys use the ford pumps, its just a matter of finding the connector and who has the pump for a good price
Old Jul 14, 2009 | 08:48 PM
Gene Culley's Avatar
Talking
With all due respect they are not the same.
The one on eBay does 320 GPH (Gallons Per Hour).
Here is what the GM service manual says.
The supercharger has an integrated intercooler. Cooling the air enhances the effectiveness of the supercharger. The intercooler uses conventional coolant in a separate sealed system from the engine cooling system. The intercooler system has a radiator, a reserve tank/filler neck, a pressure cap, attaching hoses, and a pump capable of a 26 liters (7 gallons) per minute flow rate. The pump is commanded ON, by the control module, whenever the engine is running.
7 gallons per minute x 60 = 420 GPH.
The Bosch numbers on both are different as well.
I will say that for my recent SC project I bought the one for the Ford Lightning (320 GPH) on eBay for $89.95.
Old Jul 14, 2009 | 09:24 PM
qwikredline's Avatar
based on what I know 5 gpm is what they are really capable of; the service manual (dont know what generation you have) is repeating information that may not neccessarily correct....
x 2................
Last edited by qwikredline; Jul 14, 2009 at 09:24 PM. Reason: Automerged Doublepost
Old Jul 14, 2009 | 09:45 PM
Talking
x 2................
Well, all I can say is that the actual Bosch numbers on the pumps are different, so that would give me an indication there was a GPH difference.
Since I am a GM Employee, I use the electronic service manuals, which are always up to date.
Old Jul 14, 2009 | 10:12 PM
shadowfaxss's Avatar
I ordered mine from OTTP.....should be here any day.
Old Jul 14, 2009 | 10:16 PM
Maven's Avatar
Up to date sure, but hardly accurate, there lots of errors in the manual.
I found a new error just today.... look up this document tell me its "up to date" Doc ID#768089
Old Jul 14, 2009 | 10:47 PM
Gene you can trust Maven. And I did extensive testing with GM on pumps; we were the guys who figured out redlines were wired backwards. Anyhoo any of those bosch pumps are good and you got one lol
Old Jul 14, 2009 | 10:58 PM
OneCOLDBIZL272's Avatar
your stock cobalt ic pump flows 317gph.
im running the merziers pump wp136s pump flow is 1200gph note this will go down some after running threw the system but the pump is better than stock and seems to be out doing the factory pump im seeing better ait2 temps and when they rise they drop quicker and seeing a stronger flow that of stock pump. im sure that i posted this now zoomer from zzp will be here shortly to talk crap....note you have to do alot of fabing for the pump im running. but theres nothing wrong with running the factory pump or another one, the stock one just wasnt going to cut it for me with all the stuff i have in my motor now.
Last edited by OneCOLDBIZL272; Jul 14, 2009 at 11:03 PM. Reason: Automerged Doublepost
Old Jul 14, 2009 | 11:03 PM
copy that good work; Sharkey in BC is running the merziere also and likes it fine...10-4 on the fabbing...if you run an LE5 pan for better oil control in corners you gotta fab a bracket for the stock pump anyway...and 10-4 on the zumah...
Old Jul 15, 2009 | 08:50 PM
Talking
Yes, there are errors in the manuals, but they are up to date, lol.
Like I said, the Bosch numbers are different and the costs are much different, so that would indicate a difference to me.
Maven or the mighty John.
Can either of you look at my thread and tell me what you think about my MAP sensor? Remember, I supercharged the 2009 LAP engine and this is the first one that is being done and first LAP SC to be tuned by Vince.
https://www.cobaltss.net/forums/show...166563&page=16
Last edited by Gene Culley; Jul 15, 2009 at 08:50 PM. Reason: Automerged Doublepost
Old Jul 15, 2009 | 09:44 PM
I am totally not qualfied to comment on this, try a pm to Area 47 he is one of the best but there is a limit to what guys will do for free...also Josh at OTTP Fast98 is pretty sharp on this stuff...
Old Jul 16, 2009 | 10:46 PM
Talking
Thank you for your information. I'll keep working on it.
Old Jul 20, 2009 | 11:35 PM
megaman311's Avatar
has anyone even been on the bosch website for these pumps? They only have one option for the inlet and outlet sizes that we use.
Old Jul 21, 2009 | 01:16 AM
IonNinja's Avatar
whats the price after shipping? i think i will be in the market for a new pump soon
Old Jul 21, 2009 | 01:49 AM
ottp sells them for 100 bucks zzp sells them for 199 ottp is the cheapest i have seen a stock pump selling
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
importkiller
Sep 30, 2015 07:18 PM
Sep 27, 2015 08:53 PM
