Intercooler Pump Problems.
Old Jul 2, 2007 | 01:02 PM
Ljavy17's Avatar
So yeah, My if I go WOT, the car will stay at 160 IA2Ts, and it wont go down, I looked in the place where you fill the coolant for the intercooler setup and there is no movement, Do you guys think this could be the intercooler pump, thats what I think it is, How much do you guys this it costs?
Old Jul 2, 2007 | 01:50 PM
Area47's Avatar
Rent me! per hour
blown fuse?
Old Jul 2, 2007 | 02:44 PM
pierre's Avatar
Sounds like the pump. Was it working better before?
In case you don't know there are places other than the dealer to buy them
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Jul 2, 2007 | 02:48 PM
fsickness's Avatar
What do you mean by 160 IA2Ts? And what is an adverage temp to run I have been like 210-225 now but when I got the car it was 180-187. Sorry I know a lil off topic.
Old Jul 5, 2007 | 03:53 PM
Ljavy17's Avatar
sometimes it works sometimes it doesnt
Old Jul 5, 2007 | 04:08 PM
BravoPuma6's Avatar
i already told u man, gimme a call so we can see ur pump
Old Jul 5, 2007 | 04:24 PM
yellowcobaltss05's Avatar
better not blow up!!!
Old Jul 15, 2007 | 08:05 PM
Ljavy17's Avatar
Can anyone confirm that this is in fact the actual Pump the cobalt uses too.
Old Jul 15, 2007 | 08:13 PM
M88ArRamadi's Avatar
I'd like to know that too
Old Jul 15, 2007 | 10:19 PM
Ljavy17's Avatar
cmon guys!!
Old Jul 16, 2007 | 01:03 AM
Matty's Avatar
Paul (06blackg85ss) uses that one. I read over on the Redline forum a few others do as well.
Old Jul 16, 2007 | 11:42 AM
2K5SS/SC?'s Avatar
LJ, did you check the fuse in the black box under the hood? Also, there is a connector that clips onto the pump, is that still connected? Also check the ground that is next to the starter as well.
Old Jul 17, 2007 | 12:35 AM
Ljavy17's Avatar
im gona check the fure under the hood first. I havent done any of the above. Maybe I blew the fuse because my meth is wired in the fuse box and it actually stopped working one day after I went WOT.
Old Jul 17, 2007 | 12:56 AM
ItalianJoe1's Avatar
Check the fuse and relay under the hood, check the plug on the pump itself. Then hit the pump with a hammer, it can maybe get it spinning again and then you know you need to replace it.
Old Jul 17, 2007 | 01:21 AM
Ljavy17's Avatar
it actually works sometimes joe, but its off most of the time.
as weir as it sounds, it works when I make left turns most of the time!
Old Jul 25, 2007 | 06:26 PM
Ljavy17's Avatar
Found the problem!
The ac was leaking water in the connector of the pump so after a while the pump would shut down because of the water. thats why when I would start the car it woud work for a while until the water would get to the connector and stop working. SO I put a bunch of tape around it and problem fixed~!!
Old Jul 25, 2007 | 09:26 PM
Shermen's Avatar
since this is an intercooler pump thread. has any one put a larger intercooler pump, or a faster one? (meaning one that moves more liquid faster.)
Old Jul 25, 2007 | 11:31 PM
stonny9's Avatar
It is said that the stock pump is sufficient. Just due the dual pass and/or second/larger heat exchanger
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
