intercooler removal
intercooler removal
if you remove the intercooler setup, pump coolant all of it and the car beeps and tells you ou have low coolant because nothing it there, does it then limit boost at all or go into any safe mode settings?
no ideas?
no ideas?
i took off the intercooler the pump and all hoses. we had the car setup to run the intercooler all the time as well as the fans. so i do need to go to see fred and turn that stuff off
i used to get the low coolant light all the time in the winter for the intercooler coolant. but ill check my coolant level again and see where it is at. but i think maxim x is right ive got to turn off the intercooler pump and fans to set everything correct
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
