Intercooler Resevoir new mod idea
Old Aug 2, 2006 | 08:16 PM
sethallen's Avatar
would a larger i/c reservoir with the stock h/e setup do anything? also, anyone had progress with this?
Old Aug 2, 2006 | 08:18 PM
vandy0419's Avatar
Yes and yes because that little cap in the pictures is actually where you drop ice, or what I'm using, dry ice, in it to chill the intercooler fluid which has shown very promising. I have seen it to where the temp drops 25-30 degrees and gains 20whp. The guys from Torque Forward have one but chose not to release it for numerous reasons for either the RL or CSS.
Old Aug 2, 2006 | 08:56 PM
denny's Avatar
Originally Posted by vandy0419
Actually, LFP, the place that made that one for the Cobra is making one for the cobalt and will be out here in a couple weeks. They also have one for the RL that will actually fill up the whole left side of the engine bay, back to front, left to right, will even have an angle for the front part!
I made the mock up of it, should get here early next week with the actual prototype! If anyone has seen a RL up close and personal, you will see how much larger the RL area is than the CSS. The one for the RL is larger than the Cobra's. But the LFP design for the Cobalt will incorporate everything for the most room possible so expect to see it maybe mid August!
Oh and tomorrow I should have dyno numbers and IAT2 drops for the LFP HE...
PS: LFP has been trying to get set up as a vendor, but no one is helping them out with it! I gave them one of the IDs a while back of one of the admins to get set up.
That's awesome news!! Tell LFP to contact : info@cobaltss.net to become a supporting vendor. You probably already know but Jonel is the man to talk to. He is the site admin/owner he is usualy very quick at answering his e-mails.
Cant wait to see the results on your IAT2 drops and Dyno.
Old Aug 2, 2006 | 11:57 PM
cashstacker's Avatar
Wouldn't the coolant reservoir be the tank right by the strut on the driver side?
Edit: it's the overflow but would it help to put ice in that one?
Old Aug 3, 2006 | 01:02 AM
Cobalt_Supercharged's Avatar
That is the engine coolant. The reservoir for the IC system is the little tube at the front of the engine bay. LFP is making a larger one that will go on the passenger side of the car.
It really wouldn't help if you ice the engine coolant unless your engine temps are really high. If you lower it below the 180 where the engine is designed to run, it could actually decrease the efficiency of the engine. You would make the engine run richer to increase the engine temp back to the optimal operating temp.
Old Aug 3, 2006 | 01:53 AM
leviticus88's Avatar
Please keep us posted with the results of these mods, Im excited for the aftermarket h/e and res. This is potentially my next mod.
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
