intermediate shaft
Old Dec 5, 2007 | 12:15 AM
brownbandit9's Avatar
intermediate shaft
so can that well known gm problem with the intermediate shaft/steering column popping noise be ignored...or will this eventually cause a problem..i have no warranty so hoping i can ignore it if its not dangerouse or problamatic
Old Dec 5, 2007 | 03:05 PM
does nobody know anything on this...nothing puts me in a grumpier mood than when something is not right with my car...its so frustrating to just drive around ..any imput please...
Old Dec 5, 2007 | 03:35 PM
kanabrewski's Avatar
Per a tech in back in the shop. the intermidiate shaft was not lubed properly at assembly. It will need lube when you can get it done., it's prolly rusted like mine. I'm doing mine when i get the stage 2 axles. You'll be alright for a bit. But when you get an oil change done have them check it.
Old Dec 5, 2007 | 03:50 PM
selfinfliction's Avatar
the intermediate shaft clunking is covered under a TSB, if you take your car to the stealership they will order a new one and replace it free of charge. i've had mine replaced already and it took about 4 hours or so to get finished with the job.
i can get you the TSB number if you want, but the dealership will have to verify it anyway.
Old Dec 5, 2007 | 06:06 PM
NO WARRANTY THOUGH..is no warranty still repaired under tsb....
Old Dec 5, 2007 | 06:47 PM
ptrblkz24's Avatar
No.Its only covered if its recalled.
Old Dec 5, 2007 | 07:11 PM
montecarloman's Avatar
The I-shaft is not the only thing it could be, thought it is the most likely. I-shaft replacement in Suburbans, Tahoes, C/K trucks, and Impalas is very common. Cobalts rarely suffer from specifically this. Several different types of rattle have been identified and listed in TSB #04-03-08-006B. The steering column, I-shaft, and or loose PCM/TCM all could cause some or all of your noise.
Turbo Johnny
Feb 21, 2019 09:41 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
medic710
Sep 6, 2015 08:53 PM
