internals
Old Aug 22, 2010 | 02:45 PM
PJ09's Avatar
internals
how much boost can the stock internals handle?
Old Aug 22, 2010 | 03:34 PM
spitefulxcheerio's Avatar
I will go ahead and say 25lbs. But why would you ever run that? Its probably more than 25 but you'll have no reliability on the engine.
You'll never run that much on the stock blower and you won't need that much with a bigger blower. Also, if you're thinking turbo, then only with a small turbo would you see that much boost. Go big turbo and you won't need that much boost
Old Aug 22, 2010 | 03:50 PM
JHans5774's Avatar
Boost?????? Do you mean hp? Boost is not a measure of power
Old Aug 22, 2010 | 04:03 PM
PJ09's Avatar
i meant boost, like the pressure put on the engine. And im not planning on going anywhere near 25lbs. I just had an argument with my friend who said that anything higher that 15lbs would blow my engine, and i told him he was wrong.
Old Aug 22, 2010 | 04:05 PM
ItalianJoe1's Avatar
boost doesn't mean anything. power is what breaks parts.
TurboTechRacing's Avatar
It all depends if your setup is tuned correctly.
Old Aug 22, 2010 | 04:06 PM
06SIBLT's Avatar
what are up you ss/sc or ss/tc? Its not all about how much boost, its also heat and the amount of pressure you are running into the head.... all about pressure, not boost.
Old Aug 22, 2010 | 05:08 PM
selfinfliction's Avatar
4006 psi
Old Aug 22, 2010 | 06:20 PM
PJ09's Avatar
i know about the heat, when i start my build i have plenty of cooling mods drawn in. Maybe a dumb question but is boost not the added psi that is going into your eninge.
Old Aug 22, 2010 | 06:30 PM
06SIBLT's Avatar
Originally Posted by selfinfliction
4006 psi
0n an m62!
its 9006 for a 3071r lol
Old Aug 22, 2010 | 08:55 PM
Stone629's Avatar
Nope. The PSI you see is intake manifold pressure. Boost doesn't equal HP. In fact, the more you are able to lower your boost, the less restriction you have in your exhaust, etc. I started off at nearly 20lbs with the 2.8 pulley and 7k rpm. Once I opened up my exhaust a tad, I was able to drop it down to 17lbs... which is a good thing and equals more power.
Old Aug 23, 2010 | 12:19 AM
PJ09's Avatar
ok thanks man, im new to alot of this.
Old Aug 23, 2010 | 11:17 AM
Originally Posted by 06SIBLT
0n an m62!
negatory on the 9006 psi.... i have metal shavings in the oil pan, do not believe there is much life left in the engine
Old Aug 23, 2010 | 11:20 AM
BLAZIN07SS's Avatar
I'm too JDM for you
tell your friend to end himself. boost is irrelevant. its about cylinder pressure
Old Aug 23, 2010 | 12:29 PM
Gabi's Avatar
x2
Old Aug 23, 2010 | 12:56 PM
So, when my car was getting 14psi out of a 2.8" pulley, that was less power than the guys getting 18psi out of the same pulley, right?
Old Aug 23, 2010 | 12:59 PM
BLAZIN07SS's Avatar
I'm too JDM for you
of course! moar boost fgt!
Old Aug 23, 2010 | 01:01 PM
Damn, I knew the car wasn't as fast as it should of been. I could only just barely beat a C6.
GaryGibblez
Jan 14, 2020 10:35 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
TylerJHowell
Sep 21, 2015 06:47 PM
revready
Aug 30, 2015 11:04 PM
