Japeatr's knocking at the track rebuild thread
Old 02-29-2016, 11:38 AM
  #301
South Central *********
JapEatr's Avatar
also need to drill/tap my intake manifold for the PCV port for the head. hope to do that this coming weekend.
Old 03-01-2016, 05:43 PM
  #302
574
574's Avatar
Glad to see this coming together finally. If you have decided on a clutch shoot me a message on FB and I'll see if there's anything I can do for you!
Old 03-01-2016, 07:49 PM
  #303
63 Nova SS's Avatar
Hope it's everything you wanted it to be when its done. You have done a lot of detailed work on the car.
Old 03-02-2016, 09:43 AM
  #304
JapEatr's Avatar
thanks Nick!
Old 03-02-2016, 11:10 AM
  #305
JapEatr's Avatar
ive been sick the last few days, my goal is to get the exhaust mani, turbo, AN hoses made for oil feed/drain, fittings installed for EQP, CKP sensor and front cover installed.
Then would just be waiting on clutch parts before it gets installed.
Old 03-02-2016, 11:25 AM
  #306
Haven07's Avatar
Yea it's cray how much detail is going into this build. How long has it been since you've driven it?
Old 03-02-2016, 11:28 AM
  #307
JapEatr's Avatar
May of 2014
Old 03-02-2016, 11:31 AM
  #308
Haven07's Avatar
Damn man! Your car has been down... almost as long as I've owned my car
Old 03-02-2016, 11:52 AM
  #309
JapEatr's Avatar
it was a jackstand queen for the last 4 years
Old 03-09-2016, 12:15 PM
  #310
JapEatr's Avatar
Made some progress this week. 90% of my fittings are in, in the process of making AN lines for the drain and oil feed.
I studded the turbo manifold so the bolts wouldn't loosen and mounted the turbo and verified its orientation.
Started working out the fittings for the EWP hoses and routing.
Biggest accomplishment was drilling and tapping the 1/8"npt port for the PCV vent in the head in our OTTP manifolds.
after this next weekend I plan on ordering the clutch and flywheel.
Old 03-10-2016, 11:57 AM
  #311
JapEatr's Avatar
got the ATI and new front cover mounted last nite
Old 03-11-2016, 08:03 PM
  #312
JapEatr's Avatar
Finally ordered my clutch last nite. also scored a stock weight aftermarket LUK flywheel.
ill be mounting that up with the ARP FW/PP bolts
also picked up a set of the new ZZP coils
Old 03-16-2016, 10:22 AM
  #313
JapEatr's Avatar
time for an update:
I picked up this PRP electric water pump
got my LUK flywheel installed with ARP flywheel and pressure plate bolts
Old 03-16-2016, 12:28 PM
  #314
Administrator
Administrator
Staged07SS's Avatar
Very nice work man!
I like how you take the extra time to making everything nice and neat.
There are too many turbo builds where parts are just slapped on all sloppy.
Old 03-16-2016, 03:00 PM
  #315
JapEatr's Avatar
yeah man I would have all the lines already done but I keep changing my mind on the 45, 90, etc fittings to make routing better.
Old 03-16-2016, 03:10 PM
  #316
06blackg85ss's Avatar
lookin good man. progress is always a wonderful thing
and mine is definitely the sloppy one lol. by I don't give a f*ck.... all go, no show is how I roll.
Old 03-16-2016, 08:30 PM
  #317
Haven07's Avatar
Originally Posted by 06blackg85ss
lookin good man. progress is always a wonderful thing and mine is definitely the sloppy one lol. by I don't give a f*ck.... all go, no show is how I roll.
That last line should be a famous quote!
Old 03-17-2016, 07:31 AM
  #318
Administrator
Administrator
Staged07SS's Avatar
Old 03-17-2016, 10:34 AM
  #319
mrbelvedere's Avatar
you should have the engine in the car before you run the lines makes it easier to figure out where to put things
Old 03-18-2016, 11:41 AM
  #320
JapEatr's Avatar
John i was referring to the oil feed/drain from turbo
Old 03-28-2016, 04:28 PM
  #321
JapEatr's Avatar
spark plugs gapped and torqued, new ZZP coils in place.
Need to torque flywheel and clutch with my ARP bolts
then mate trans and install the Powell Roll Pins
  #322
JapEatr's Avatar
Also need to fab mounts for my electric water pump setup, and get the final fittings
Old 03-28-2016, 10:04 PM
  #323
call arp and get their torque specs on the bolts do not use gm specs and use red loctite
JapEatr (03-29-2016)
Old 03-29-2016, 06:49 AM
  #324
almost there man. looking forward to this one.
Old 04-06-2016, 12:57 PM
  #325
JapEatr's Avatar
update:
Engine is in, having to replan the location of the EWP mounting but now to get subframe bolted and wiring completed
Quick Reply: Japeatr's knocking at the track rebuild thread
