jb weld on my downpipe
Old Jun 4, 2008 | 08:42 PM
omgshesaboy's Avatar
hey my exhaust has the tiniest leak in between the dp and catback, i replaced the gasket and cranked it tight and its still leaking, would some jb weld do the trick? it says its safe up to 500 degrees
Old Jun 4, 2008 | 08:43 PM
JPizzle's Avatar
JB Weld is liquid steel!
Old Jun 4, 2008 | 08:44 PM
D4u2s0t's Avatar
jb weld would work fine, but if you ever have to take it apart you're going to have to cut it. and make sure you let it dry overnight before driving, otherwise the leak will spit it all off anyways and it will be a total waste of time
Frankruffolo257's Avatar
your exhaust gets hotter than 500
Old Jun 4, 2008 | 08:45 PM
JPizzle's Avatar
Wait 24 hours.... To be safe.
Good call D4.... LOL
Old Jun 4, 2008 | 09:16 PM
thanks guys
Old Jun 4, 2008 | 10:57 PM
zinner's Avatar
Moderator Alumni
Exhaust gases are about 1400F when they leave your combustion chamber.
I have hit my exhaust with my IR temp reader which goes to about 450F and it's over temp so the chance it's over 500 is pretty good.
Old Jun 4, 2008 | 10:58 PM
chris88z24's Avatar
Go to pep boys they have a certain product made just for that. I used it on all of my flanges and it worked wonders. had it on for about 1000 miles and no leaks.
Old Jun 4, 2008 | 11:04 PM
falke401's Avatar
my friend used jb weld on his exhaust maifold once. It smelled so bad you could not stay in the truck. JB weld is some toxic stuff. Just make sure whatever you use is made for high temps.
Old Jun 4, 2008 | 11:28 PM
kburgess04's Avatar
jb will not work!! i know this for a fact from past experience. yes it does smell for the frist hour or so but after that your downpipe is going to get it hot enough that it will turn to dust. does wonders for about 100 miles after that turns to chalk. but good luck bro
Old Jun 4, 2008 | 11:32 PM
Beck's Avatar
EGT's reach over 1000, jb weld wont withstand it.
Old Jun 4, 2008 | 11:36 PM
68nova200's Avatar
have you ever burned yourself on a downpipe? it melts skin instantly. jb weld will not work.
Old Jun 4, 2008 | 11:39 PM
ikeryder13's Avatar
i am having the same problem... i fixed it by ordering a ark dt-s exhaust
Old Jun 4, 2008 | 11:47 PM
fiShYs-'s Avatar
jb weld wont work, use muffer cement
Old Jun 5, 2008 | 03:35 PM
i ordered some bell automotive muffler cement
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
