jbp valve springs
Old Nov 9, 2009 | 11:02 PM
JCobalt's Avatar
jbp valve springs
i got some jbp valve springs from a friend,i was wondering if i wud be ok to take it to 8k.i beleive they are 72# pressure.the rest of my valvetrain is factory.thanks.
Old Nov 10, 2009 | 06:07 PM
JCobalt's Avatar
Old Nov 10, 2009 | 06:20 PM
hungryhip-ccp's Avatar
7800 anything more is asking alot from the balance shafts.
Old Nov 10, 2009 | 07:27 PM
JCobalt's Avatar
so if i got the neutral ones i cud go higher?
Old Nov 10, 2009 | 09:46 PM
Gabi's Avatar
i got them install, there were a post that said how high they can handle but it was really old, may be you can seach for them and find out
Old Nov 11, 2009 | 12:22 AM
JCobalt's Avatar
i tried searching but nothing came up
Old Nov 11, 2009 | 12:25 AM
MikeyB's Avatar
Im not sure what the springs are, but if there like the supertech 78# springs, all you will need is balance shaft delete or the netural balance shafts and you can take it to 8k how reliable will it be, not to sure
Old Nov 11, 2009 | 12:35 AM
rnjmur's Avatar
GM recommends not spinning the stock balance shafts at engine speeds past 7500 RPM.
Old Nov 11, 2009 | 01:36 AM
JCobalt's Avatar
dam ok
Old Nov 11, 2009 | 02:38 AM
Area47's Avatar
Rent me! per hour
no, gm recommends not sustaining rpms higher than 7500 for extended periods of time. selective read just nailed you.
Old Nov 11, 2009 | 10:37 AM
rnjmur's Avatar
No, the better question is what is considered an extended period of time? One second? Two seconds? If you want to rev to 8K you need to put in neutral balance shafts or delete them entirely.
Old Nov 11, 2009 | 01:57 PM
Area47's Avatar
Rent me! per hour
::facepalm::
Old Nov 11, 2009 | 02:29 PM
rnjmur's Avatar
There are always two ways to do things. The half-assed way and the right way. I always figure that if you are going to do it, might as well do it right. If you want to do it half assed then that is your choice. Your motor not mine.
Old Nov 11, 2009 | 02:47 PM
Area47's Avatar
Rent me! per hour
my motor has lived just fine for the past 50k miles being shifted above 7600rpms without a problem.
on stock balance shafts.
Old Nov 11, 2009 | 02:55 PM
SCcobaltSS's Avatar
Well thats good to know about the shafts, I was wondering that myself since I got springs and want to go to 8k.
Old Nov 11, 2009 | 08:28 PM
JCobalt's Avatar
yea im already on motor #2 id rather do it the right way
Old Nov 12, 2009 | 10:09 AM
rnjmur's Avatar
I'm sure that occasional blips up into the 7600 - 7700 range is ok, but the OP stated he wants to go to 8K. If he wants to go 8K I can assume he is going to be driving the car hard. I would definately do neutral balance shafts in that situation.
turbochargedss2012
Sep 20, 2023 12:17 PM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Trav3480
Sep 28, 2015 02:46 PM
