Jerky acceleration
mine is still running like trash. HPT would not read the PCM i got from OTTP. so i used the stock one and swapped over the info from one to the other. we modified that and made it a little bit better but not much. the fuel trims are all fucked up. need to hook up my wideband before we lean it out to much.
high end on the 80's are a tad rich... low end need work... idle is a bit rich... getting closer to getting the injectors figured out....
I'm not a "OTT stage 3" but i have some tricks and stages
ok, went to 21st Century Muscle Cars...which is the official Lingenfelter shop other than their headquarters in INDIANA.
Had a buddy that works their work on my tune. It was idling at 10:1 and deep in the 9s at WOT when it rolled in there
got it to 277.9 whp and 221.6wtq, but remember this was only to get the driveability worked out, not any kind of glory number yet
After pulling out tons of fuel and timing we get the AF strait as an arrow, but still having the jerk from time to time,
we are still working on getting the MAF straitened out, but i need more cash to keep going
the ride home it started to idle messed up at stop lights. I bought a set of plugs on the way home and it eventually thru a p101 code for MAF range and performance.
im gonna put the new plugs in today, clean MAF and air filter, and spray water to look for vac leaks and see if anything improves further before going back to the tuner
keep everyone posted... and yeah you still have some work to do to get those numbers where they should be. I am trying another updated tune today and ill let you all know how that works
note: that was on the 3.1, havent heard a word of when ill be getting the 2.9 that i ordered nearly a month ago
