just did my oil change... got a couple questions
Old Mar 12, 2006 | 05:40 PM
rnoggle's Avatar
First, what is the proper name for the part that is bolted to the end of the supercharger? Is this the MAF?
Second, is there any way to remove the oil filter without removing this part. I couldn't get my hand down in there at all. Finally removed the intake tube and this part and was able to get it.
Thanks for any info.
Old Mar 12, 2006 | 05:44 PM
Cobalt_Supercharged's Avatar
That's the Throttle Body. I have no idea. I let the dealership worry about that.
Old Mar 12, 2006 | 06:00 PM
bluecobaltss06's Avatar
Yeah man, put the socket on the oil filter cap, by snaking ur hand under the throttle body. Then take an extension and feed it through from the top.
Old Mar 12, 2006 | 06:14 PM
rnoggle's Avatar
lright, I'll try it like that next time.
Old Mar 12, 2006 | 06:19 PM
flobeelicious's Avatar
if you get a universal joint for your ratchet, you can use that and an extension bar, and come in from the top of the supercharger, at an angle. the uj will bend allowing a flush fit on the cap to unscrew it, then pulling it out the front of the engine through the hole beneath the sc seems to be the way to go to not get oil all over everything.
Old Mar 12, 2006 | 09:05 PM
Canada's Avatar
Lots and lots of brake clean is key.
Old Mar 12, 2006 | 09:27 PM
plyboy-illest's Avatar
my delaer has done my oil chnaged but thats cuz i had a couple of free ones and it seems to be a pain in the ass the next oil chnage im going to have to do my self so were going to see how that goes LOL
Old Mar 12, 2006 | 09:41 PM
i'd be careful with the brakleen. that stuff is not too good for paint, and very bad for rubber hoses.
Old Mar 12, 2006 | 10:20 PM
fastSS06's Avatar
I've changed my oil myself twice already, never had to unbolt or remove anything (other than the filter).
Just get a 32mm socket and an extension and your set.
Old Mar 12, 2006 | 10:24 PM
rnoggle's Avatar
i'm sure it will be MUCH easier next time. I didn't have a 32mm socket, so I was trying to use a crescent wrench. Got it done but it was a pain.
Old Mar 12, 2006 | 10:33 PM
x8xViperx6x's Avatar
It would be easier to just go out and buy a 32mm socket.. then to use a cresent wrench
Old Mar 12, 2006 | 10:36 PM
rnoggle's Avatar
yeah, but I had the car up on jack stands with the brakes off (painting the calipers) and decided to do the oil change while it was on jacks. Couldn't get to a store to buy the socket. I'll have it for the next time though.
Old Mar 13, 2006 | 12:30 AM
vanillathrilla's Avatar
Ahhhh! a crescent wrench!? Such a pain in the ass when you strip the bolt...
Old Mar 13, 2006 | 12:59 AM
patathSS's Avatar
Good ole round-off wrenches.....
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
