Just got Hp tuner
Old Jun 29, 2010 | 08:06 PM
Bl4des's Avatar
Just got Hp tuner
hey i just got hp tuner and i wanted to know if someone could look over my tune real quick to see how it is
i was dyno tuned at a shop but i would like some other people to look at it
i haven't had time to log the car yet but i pulled the tune from the car
if you want to help me out let me know what you email address is so i can email the file to you
and i did post on hp tuners forum
Old Jun 29, 2010 | 08:11 PM
ItalianJoe1's Avatar
Post it up here
Bl4des's Avatar
how remember i just got it today
i dont know how to post files on here
Old Jun 29, 2010 | 08:24 PM
Cherry GT's Avatar
I don't think you can here.
Old Jun 29, 2010 | 08:55 PM
Bl4des's Avatar
http://www.hptuners.com/forum/showthread.php?t=30126
there is a link to my hp tuner thread
i just posted some logs on hp tuner
Old Jun 29, 2010 | 09:25 PM
freakta's Avatar
whats wrong with the smg tune?
Old Jun 29, 2010 | 09:29 PM
Bl4des's Avatar
nothing really i just want some other peoples opinions on it
but it seems to stay to lean after i step on it
Old Jun 29, 2010 | 09:40 PM
freakta's Avatar
how lean is it running?
Old Jun 29, 2010 | 09:43 PM
Bl4des's Avatar
um kinda scary lean like i step on it and it stays in the 14s then starts to drop to wear it should be
maybe i have an exhaust leak that is throwing my wideband off
i have been to the track on the same tune and there was nothing wrong with it
the only thing i have done to the car sense getting tuned is a new fuel filter and change my oil
Old Jun 29, 2010 | 09:51 PM
ecot3c inside's Avatar
post up your final tune that you deem perfect! I would love to grab me an hp tuner and have a stepping stone, our mods are similar. How did you tune to the meth? advance timing after the meth kicks in?
Old Jun 29, 2010 | 09:56 PM
Bl4des's Avatar
i didnt tune it i had it done at a shop
i just got hp tuner today and want to start learning
i just wanted people to look at the tune that is on my car now
Old Jun 29, 2010 | 10:07 PM
ok, sure fooled me.
Old Jun 29, 2010 | 10:12 PM
JapEatr's Avatar
South Central *********
your link has your tune and configs, but no logs
Old Jun 29, 2010 | 10:15 PM
Dainslaif's Avatar
Depending on your PE settings, this is expected. By default, it doesn't richen up until 5500 RPM. Mine's set to 2500, a lot of people set it to 0.
Old Jun 29, 2010 | 10:21 PM
05Slowline's Avatar
Not to mention he has meth which you can get away with a ballsier afr.
Old Jun 29, 2010 | 10:28 PM
Bl4des's Avatar
ok i put one idle log on hp tuners forum that is all i saved right
and how do i change me pe to a lower rpni dont like how it is now
Old Jun 29, 2010 | 10:35 PM
JapEatr's Avatar
Engine>Fuel Control>Power Enrich>PE Enable> Delay RPM
Old Jun 29, 2010 | 10:36 PM
Bl4des's Avatar
Old Jun 29, 2010 | 10:37 PM
Dainslaif's Avatar
Up your Enrichment Rate to 2.
Old Jun 29, 2010 | 10:42 PM
JapEatr's Avatar
correct me if i am wrong, but if PE MAP enable is set at 35 KPA ~ 5.07PSI, you still must subtract 14.7 PSI to tell you what boost it enables?
Old Jun 29, 2010 | 10:50 PM
Dainslaif's Avatar
Correct. The way he has it now he can go into PE no matter what his boost is at, as long as his pedal is down enough (the TPS table) and he's above 1900 RPM.
Old Jun 29, 2010 | 10:51 PM
Bl4des's Avatar
so what does that mean is it something that needs to get change and what to
i have no idea what i am doing yet tuning wise
Old Jun 29, 2010 | 10:53 PM
Dainslaif's Avatar
Do this for starters.
Then read this
http://www.ionforums.com/forums/tuni...ve-tuning.html
Old Jun 29, 2010 | 10:55 PM
Sizzle06's Avatar
Thats a very good place to start^^^^^
Bl4des's Avatar
i did that and i will read that now
