K&N Replacement Filter
Old Oct 22, 2005 | 10:39 PM
CobaltSS422's Avatar
Not sure if everyone has seen but on K&N's website they list part number E-0777 for the replacement filter for the factory filter. K&N Replacement Filter
E-0777 Product Specifications
Product Style: Round Air Filter
Height: 7.125 in (181 mm)
Inner Wire: No
Top Style: Open
Top Material/Finish: None
Base Inside Diameter: 3.313 in (84 mm)
Base Outside Diameter: 5.25 in (133 mm)
Filter Re-Oiling Amount: 1.3 oz (39 ml)
Top Outside Diameter: 4.875 in (124 mm)
Weight: 1.5 lb (0.7 kg)
Just thought I would let everyone know if you didn't know already
Old Oct 22, 2005 | 11:42 PM
VaMP's Avatar
Hasn't this been out for awhile?
Old Oct 22, 2005 | 11:43 PM
Fingersmoran's Avatar
Inner Wire: No
Top Style: Open
What kind of power gains will i get with it? does this replace the plastic air box? Will I here the whine of the supercharger more?
Old Oct 22, 2005 | 11:57 PM
3fo893013L's Avatar
this just drops in as a factory filter replacement and gives very little gains, a real gain comes from getting a real intake that replaces the entire intake piece including the filter box. And no whine unless you do the airbox mod.
Old Oct 23, 2005 | 12:27 AM
Sneaky is correct. It just replaces the stock air filter. If you want performance gains you will need to get the CAI
The E-1009 has been out for a while but it was a little to long. I remember reading a couple members tried it out.
Old Oct 23, 2005 | 12:30 AM
3fo893013L's Avatar
Yes it has
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
