Knock sensor...
Old Sep 6, 2008 | 11:09 PM
ItalianJoe1's Avatar
Knock sensor...
Where is the Knock sensor on the LSJ, is it the little one under the closed end of the fuel rail, that looks like a MAP sensor?
Old Sep 6, 2008 | 11:50 PM
Dennisscars's Avatar
Right above the starter solenoid, a black round thing with a black wire. To the left of the crank sensor.
Old Sep 6, 2008 | 11:54 PM
Ok. What is the other sensor that I'm talking about then... it looks just like a map sensor to me, its 3 wire, hanging off the bracket for the coolant overflow hard line, just under the end of the fuel rail. Any idea?
Old Sep 6, 2008 | 11:57 PM
Raven SS's Avatar
u are correct it is the map sensor..and rears iat2's...
Old Sep 7, 2008 | 12:00 AM
Sunburst_SS's Avatar
baro sensor
Old Sep 7, 2008 | 02:50 AM
Not that one, that one is in the mainfold, by #1 piston. This is on the other end, over the trans. Looks like it, but its out in the air.
Originally Posted by Sunburst_SS
baro sensor
What does it measure? I mean, I know what baro is, but what does the car use it for?
Last edited by ItalianJoe1; Sep 7, 2008 at 02:50 AM. Reason: Automerged Doublepost
Old Sep 7, 2008 | 10:22 AM
well, not 100% sure....but I would think it uses it as a reference for the MAP sensor. Since the MAP sensors in the car are under pressure from the supercharger (like wot stuff). Make sure everything is working right.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Meadowvalien
Aug 17, 2017 06:32 PM
Tupp
Sep 30, 2015 08:18 PM
OrngBalt
Sep 16, 2015 07:45 PM
twilson380
Sep 14, 2015 10:52 AM
