laminovas for single pass???
Old Aug 16, 2010 | 09:16 PM
StevesBlack06's Avatar
for some reason when i got my single pass manifold from ZZP the cores werent with it. they later sent me the cores but im not exactly sure the correct order to put them in. im assuming it should go OoOo from top to bottom but im not sure. i would call them but they are a pain to deal with over the phone unless you are talking to the right person. thanks in advance css
Old Aug 16, 2010 | 10:23 PM
Bluelightning's Avatar
Got Bewst?
I'm pretty sure it would go oooo. Because o is in and O is out. Like a oOoO is stock, dual pass is OooO so i would assume single pass would be oooo because it's exiting out the other side, not coming back towards the end plate
Old Aug 17, 2010 | 07:49 PM
i always thought o was out and O was in. i totally spaced off calling ZZP today. maybe ill do it tomorrow...
Old Aug 17, 2010 | 10:11 PM
Got Bewst?
Definalty not. o is in and O is out. Just installed my ZZP dual pass on the weekend
Old Aug 18, 2010 | 07:55 PM
i just got off the phone with zzp and they said its OOOO not oooo
Old Aug 18, 2010 | 10:29 PM
Got Bewst?
OOOO towards the end plate?
Old Aug 18, 2010 | 10:37 PM
bykryder83's Avatar
Yes OOOO towards the endplate according to turbo tim @ zzp
Old Aug 18, 2010 | 11:08 PM
Got Bewst?
I thought it would have been one way or the other haha. But good to know
Old Aug 19, 2010 | 05:06 PM
ebristol's Avatar
He is right because the coolant enters the left side of the IM and exits on the endplate side.
Old Aug 19, 2010 | 05:55 PM
Got Bewst?
Ohhhhh thats why. Did not know that it went through the left side first. So i was right but coolant entering the wrong side haha.
Old Aug 19, 2010 | 08:02 PM
says who? and why? i dont think thats correct. if this is true whats to say the top cores are getting coolant... if it enters on the endplate side it has gravity in its favor...
Old Aug 19, 2010 | 08:11 PM
Got Bewst?
It would have to enter on the left side if all the cores are OOOO because O is exit, not enter
Old Aug 19, 2010 | 08:17 PM
take a look at the ZZP single pass manifold and see if you agree with what was just said... i cant see that being correct... you would be overworking the ic pump and you would be forcing coolant through the cores. which means slower GPM or whatever its measured in. the idea of a singlepass is coolant volume and velocity. if it flows from bottom to top you have gravity on your side aswell...
Old Aug 19, 2010 | 08:50 PM
bykryder83's Avatar
I highly doubt zzp is wrong....this was built for turbo tims car btw, and I spoke to him personally
Old Aug 19, 2010 | 08:56 PM
Got Bewst?
Did you look at you're stock cores and hoses before it came apart? Stock is oOoO. It enters in o and exits O. Dual pass is OooO. The 3rd fitting they add is in the middle of the plate where it enters oo and exits the outer O's.
Old Aug 19, 2010 | 09:05 PM
Rodimus_Prime's Avatar
Yes it enters through passenger side and exits through drivers side, when you pull off the end plate the big side of the lamova should be there for the out
Old Aug 19, 2010 | 10:19 PM
Got Bewst?
I was trying to find you're post of you're 200 IAT's because i know you had pics on there. But there ya go
Old Aug 20, 2010 | 02:29 PM
Zooomer's Avatar
Supporting Vendor
I have discussed with the crew so everyone is on the same page. The system is supposed to come assembled. My apologies.
Old Aug 20, 2010 | 10:20 PM
thanks zoom.
explain to me why... it makes no sense to try to force coolant UP through the manifold cores...
Last edited by StevesBlack06; Aug 20, 2010 at 10:21 PM. Reason: Automerged Doublepost
Old Aug 21, 2010 | 10:30 AM
Actually thats exactly why. If you have it enter through the drivers side which is higher than the exit, the top 2 cores will never fill up or be used, you want all 4 to be used which is why it has to go through all of them before it can exit.
Old Aug 21, 2010 | 01:40 PM
Idk... It just seems like you would be overworking the ic pump is all
Old Aug 21, 2010 | 06:06 PM
ebristol's Avatar
That is how it is setup from the factory?
Old Jun 27, 2011 | 04:00 PM
red06SC's Avatar
I'm putting mine back together and began questioning this. Small opening cannot be an inlet if my manifold was correct when it came apart.
I've always had mine top to bottom:
o
O
o
O
....coolant flows in through the bottom fitting up towards the filler neck...
Old Jun 27, 2011 | 09:59 PM
xxxxsh4d0wxxxx's Avatar
Sub'd
Old Jun 27, 2011 | 10:11 PM
Leafydialupking's Avatar
Small opening is the restrictor on the outlet of the core.
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
agentirons
Oct 16, 2015 02:11 AM
goaliemo
Sep 28, 2015 01:37 PM
