LC-1 Connection Problems
So today I installed the Innovate LC-1 wideband. The problem is, when I plug in into my laptop I get this error: "No Real Time Data Detected" and says to check the connections.
All my connections seem fine. Is there anything I should check? Does anyone have any idea? Thanks!
Did you use the loopback plug and did you make sure both plugs are seated properly?
It takes a little extra push to make sure the connects are seats properly.
Also I hope you utilized the LED wire for the error codes.
