LC-1 Connection Problems
Old Apr 21, 2007 | 04:50 PM
KillerNutz's Avatar
So today I installed the Innovate LC-1 wideband. The problem is, when I plug in into my laptop I get this error: "No Real Time Data Detected" and says to check the connections.
All my connections seem fine. Is there anything I should check? Does anyone have any idea? Thanks!
Old Apr 21, 2007 | 07:54 PM
Mikey851's Avatar
Did the wideband come with a connector pinout? If so you should be able to use a voltmeter to verify if everything is working correctly. It's suprising how ofter there is a problem that just cannot be seen visually; you need to check it electrically.
Old Apr 21, 2007 | 09:05 PM
zinner's Avatar
Moderator Alumni
Did you use the loopback plug and did you make sure both plugs are seated properly?
It takes a little extra push to make sure the connects are seats properly.
Also I hope you utilized the LED wire for the error codes.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
