LC-1 question
Old Dec 30, 2010 | 09:38 PM
myfakeevo's Avatar
LC-1 question
Here is the dumbest question someone will answer today...
I have a LC-1 hooked up on my downpipe, question...do i have to use a innovate motorports gauge with it or can i use any air/fuel ratio gauge (and i dont mean dummy gauges either).
Old Dec 31, 2010 | 10:48 AM
Jn2's Avatar
Jn2
the lc1 puts out a 0-5v signal, technically you can use any gauge that works with a 0-5v wire in put...to connect the lc1 to their gauges, you just soder them together, so you should be able to do it with another gauge...considering that gauge was made to accept a 0-5v signal wire
Old Dec 31, 2010 | 08:37 PM
paddock's Avatar
Could you hook it up to an Aeroforce gauge.. (interceptor)?
Old Dec 31, 2010 | 08:39 PM
myfakeevo's Avatar
your ob2 does do the o2 sensor, but i have an aftermarket downpipe with no cat so i had to re do my sensor
thats why a lot of people have a air fuel ratio gauge
Old Jan 2, 2011 | 08:42 PM
Jn2's Avatar
Jn2
youshould be able to jook it up the interceptor, i think it has a 0-5v input on it, you can connect it to anything with a 0-5v signal input that translate to a/f....meaning some gauges also accept a 0-5v signal and just translate it differently...so get a a/f gauge that will work with a 0-5v source and your set
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
