leaking coolant, possible water pump?
Old Sep 8, 2009 | 01:05 PM
bernandovelasquez's Avatar
well I hope someone can give me alittle info, today my car leaked out all of it's coolant twice, and I looked under the car and saw that the coolant was leakin near the passenger wheel but from the engine, someone told me it was the water pump but I'm not sure, does this sound right ? and should I buy a new water pump?? I'm not even sure if thats what its called.... also do you know where I can purchase one from online? thank you for your help guys.
Old Sep 8, 2009 | 01:19 PM
JapEatr's Avatar
South Central *********
The water pump is located behing the timing cover. There is an access panel on the read of the engine by the tensioner. take off the four 10mm bolt and have a look
http://media.photobucket.com/image/e...05/03wpump.jpg
http://media.photobucket.com/image/e...e/DSCN0686.jpg
they make a special tool for holding the timing chain in place
Old Sep 8, 2009 | 01:45 PM
thanks for ur input mang! so u think it wud b my water pump gone bad?? do u know where I can buy one ? don't want to buy the wrong thing and when I search for water pumps I see complete different things in the pictures.
Old Sep 8, 2009 | 02:14 PM
Maven's Avatar
If you dont even know where to buy a water pump or what it looks like i would just take it to a professional to have it repaired
Old Sep 8, 2009 | 03:40 PM
http://www.oehq.com/acdelco-parts_25...SS%202.4L.htm#
is this what I need ?
bump for some help
Last edited by bernandovelasquez; Sep 8, 2009 at 03:40 PM. Reason: Automerged Doublepost
Old Sep 8, 2009 | 06:05 PM
JapEatr's Avatar
ya man, also i would type that 89........ part number into crae engine depot or gmpartsdirect to see your cheapest option
i am biased between Mavens comment and your situation.... this is not just a bolt on ordeal, youo need at least have an idea of what you are attempting before tear down begins...
but you can figure it out if you at least know TDC and you can reference the build book chapters online for the timing chain line up in worst case scenario.
you should have a look at the access cover before buying to see it there is fluid leaking in there...
also if you do it, you may have to pull the exhaust manifold off to gain access to the coolant tube and the back half of the pump assembly.
GL mAn
Old Sep 8, 2009 | 06:13 PM
umrdyldo's Avatar
Find exactly where it is leaking and we will help.
Old Sep 8, 2009 | 06:44 PM
Jn2's Avatar
Jn2
sounds like its time ot upgrade tot he zzp electric water pump...if they ever choose to release it
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
riceburner
Sep 26, 2015 12:57 AM
