leaking tranny fluid
Old Oct 23, 2006 | 08:11 PM
sunfirejoe's Avatar
k guys, im begining to leak transmission fluid, and imnot gonna give up on this car lol, too much time and money into it already, my big question is, can you see the tranny casing crack, i belive its just an axle seal
so my question does anyone offer new seals, and how hard are they to change
Old Oct 23, 2006 | 08:17 PM
06blackg85ss's Avatar
if its leaking near the block... then I don't even want to say anything... but if its just the axles seals... easy fix
Old Oct 23, 2006 | 08:18 PM
I"ve seen two broken casings this week alone... both were cracked inside the bellhousing cause fluid to leak at the bottom where it bolts to the motor
Old Oct 23, 2006 | 08:19 PM
rally's Avatar
If the case is cracked your screwed. GM Document ID # 1864872 refers to this (not a Service Bulletin but Preliminary Information available to GM employees only)
If you goto your dealer they'll see this and deny you all of your warranty. Look for stiffer hardware and axles in the 2008 model year. Otherwise a cracked case you need to get a new tranny.
Oh yea, all of this is caused by excessive wheel hop. GM looks at it as abuse.
Old Oct 23, 2006 | 08:20 PM
sunfirejoe's Avatar
did i ever ask about warranty no, i ave blackballed warranty from day 1, so yah, and its coming from the axle its self i believe, i think its coming from the axles, and dripping down to the bottom which gets closer to the block, maybe ill go take a a good look again, i bet pictures wil help my case lol
Old Oct 23, 2006 | 08:22 PM
so it shouldn't be that bad to fix... but even with breaking both axles... I still didn;t have a leak... what you do to the thing
Old Oct 23, 2006 | 08:24 PM
rally's Avatar
Calm down, tryin to help and you snap about warranty. Seeing as its still within the warranty terms I thought you might like the info.
Sorry For TRYING to help.
Old Oct 23, 2006 | 08:26 PM
oooh missed the part about going to the block... umm... I wish you luck man... how much leaked out
Old Oct 23, 2006 | 08:27 PM
sunfirejoe's Avatar
lol, i think it was putting it i broke the seal, but maybe i got a cracked housing, well im goign otuside, wiht some brake clean
Old Oct 23, 2006 | 08:28 PM
sunfirejoe's Avatar
its jsut a light drip but liek i siad it drips right from the axles to the bottom bolts
so that why i tihnk its a seal
Old Oct 23, 2006 | 08:40 PM
sunfirejoe's Avatar
after a kick updity do, in the air, i find that its just leaking from the axle
so who can get me a good deal on a new seal
Old Oct 23, 2006 | 08:43 PM
lucky guy
Old Oct 23, 2006 | 08:48 PM
sunfirejoe's Avatar
yah i gonna **** my pants here soon, lol, i got myself almost every wheel hop mod possible, from cab's to lowered, to torque dampners and engine mounts, next on my list is traction bars if i need them lol
Old Oct 23, 2006 | 08:57 PM
mccustomize's Avatar
i just got mine out of the dealership for it leaking tranny fluid, the case was cracked and 4th gear had a tooth chipped off of it, they warranteed it, new tranny and all
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
