"Lightweight" 3" Stage 2 style pulley
Hi all, here's a 3" pulley for the GM stage 2 with custom lightening holes drilled!
Truth be told I drilled the first set with the incorrect offset so I then re-drilled it correctly.
Is anyone interested in it?
Nate
www.smoothflowpulleys.com
sales@smoothflowpulleys.com
Nate
I like it, the lighter the better. If I still had my ss/sc I would take it. I wouldn't see it being much lighter than its already EXTREMELY light weight but every little bit counts. Any thoughts of making some light weight pulleys for the ss/tc?
Well I would say if know one does buy it you could use it as a paper weight, but that thing is so light if the wind blows to hard or you sneeze in that direction it will be blown away! Anyway here's a bump for you, like I said above if I still had my SC I would take it off your hands. Some one should jump on this, you would not believe in the difference in weight over the stock brick of a pulley the stage kits come with.
