LNF engine and trans mounts
agreed. The mounts go to **** if you drive it hard. I couldn't beleive how loose the stock mounts were when I pulled em out. I could easily twist the inner part of the bushing by hand. One other thing I noticed is the axles like to go bad and start making a clicking noise. Had an axle replaced once under warranty, and the other tightened up. The one that didnt get replaced is starting to click again from time to time. I expect **** to break the way I drive, and I don't have a problem replacing things. Usually it gives me a chance to upgrade the failed part.
agreed. The mounts go to **** if you drive it hard. I couldn't beleive how loose the stock mounts were when I pulled em out. I could easily twist the inner part of the bushing by hand. One other thing I noticed is the axles like to go bad and start making a clicking noise. Had an axle replaced once under warranty, and the other tightened up. The one that didnt get replaced is starting to click again from time to time. I expect **** to break the way I drive, and I don't ahve a problem replacing things. Usually it gives me a chance to upgrade the failed part.
I did some research and cross referenced a couple pictures. The first one is the picture of the LNF mount on crate engine depot's website. The second is a picture of a 2006 lsj stock mount by a redline forum member.
I see no differences, so I guess the only question is if the picture on the crate engine depot website is a picture of the actual part. Can anyone post pics of their stock LNF mount?
Isn't CED a forum vendor? Maybe they could help me out with my question about the pic
