LNF exhaust on a LSJ?
mandrel exhaust systems have shitty fitment, i sold mine that i had on. the tc exhaust is about 4 inches or so shorter then the ss/sc exhaust so you have to shop off the flange and have some extra pipe welded on, then id suggest getting rid of the 2 bolt flange on your dp and find another stock 3 bolt flange
I guess the more Of the exhaust that's 3" the better? Also I'm going to assume the 3 bolt flange will work better than 2 bolt. Do you have any pictures of your setup?
the flange on the tc exhaust is a 3" flange i believe so if you buy another flange either stock or from zzp and weld it on to the 3" zzp downpipe after you add the extra piping youll be good. i actually went v-band clamp and ditched flanges all together but the clamp alone was like 100$
#36
All you would need to swap on the LNF catback to get it to bolt to the SS/SC's downpipe would be the connection flange. That's a pretty simple/cost effective fix to have a 2.5" catback that will fit like stock, and flow better.
#37
because the TC catback is 2.5 all the way back, has a stock resonator with a bigger inlet then the SC catback and a better flowing stock muffler. The SC catback has a small resonator inlet, crimped over the axle portion and an extremely restrictive muffler. The TC could probably be picked up for cheaper then the over the axle portion and would probably yield more gains.
also the TC catback should keep it quieter than replacing all the restrictions in the SC catback
Last edited by Tarheel62592; 04-27-2011 at 11:56 AM. Reason: Automerged Doublepost
#39
no problem, im seriously considering this but im worried about how the LNF catback would handle my badmab header and 3" CTI catted downpipe, worried about rasp and it being too loud. Any input on this?
#40
Maybe put on a glass pack in place of the resonator? I've read in a couple threads from different people that the glasspacks really keep noise down and don't cause any restrictions. I am wondering myself what to do I have the ZZP LTH and catless dp waiting to be installed but I don't want to mate it with the stock exhaust in fear it will sound like crap.
#43
There is a another problem area in the stock LSJ catback, and that's at the inlet of the resonator. I guess you could just swap out the resonater & over axle piping of the stock LSJ catback, and be ok, but if it's cheaper to get the LNF catback I would go that route.
Thanks,
Ryan
#44
Well the CTI over the axle section in 2.5" is $265 plus shipping on OTTP. The full 2.5" catback from mandrel bent exhaust systems was $285 shipped so I would just go that route if I had to. Looks like I'm still going with the LNF catback and swapping out flanges. Might just cut out the stock LNF resonator and run a straight pipe to see how that sounds. I can always add a glasspack or different resonator later if I have to.
Thanks,
Ryan
Thanks,
Ryan
#48
I had one on my 06 ss/sc. had the flanges converted from the 3 bolt to the 2 bolt lsj. fits on like stock. if the car has a stock manifold and dp....sounds REALLY good. Change the dp though....and for some reason it is loud!
Cheap mod to do if you have access to one. I got rid of mine (its in the back of the shop here at work) because of the noise it made......BLLLLLLLAAAAAAAAh BLLLLLAAAAAAAAAHHH
#49
YouTube - Cobalt SS 2.4L LNF Catback -resonator.
I realize it is a 2.4L but we need someone to post it on the LSJ
