long road to ruin
Area, IIRC, is running straight distilled H20 during summer months. As for heat disipation = Dexcool (Good) << Water+Dex-cool (Better) << 100% Distilled Water (Best)
Rent me! per hour
actually i have not touched the aftercooler fluid since i put the front mount on the car. it is more water than dexcool, but not enough to make a huge impact.
plus there is some air flow modifications that are not visible to the average person.
:X
:X
Rent me! per hour
occasionally i know what im talking about
Rent me! per hour
lawl
::runs::
i'll give ya a call when i get off work
Rent me! per hour
17-18 psi.
street tune
332/261
boost doesn't come in hard till 5k. hence the low torque. damn 3.1 pulley
dyno tune. ***** out
342/267
comes out to be 393 at the crank going of a 15% draw
based this off my 290/257 m62 run.
street tune is at 19-20 degree's of timing.
dyno blast runs are not to be published
graphs to come later when i get em e-mailed to me
street tune
332/261
342/267
Rent me! per hour
the first pull was at 10.3 afr. that was 320 out of the box. then leaned it out from there. i do need to do some major maf tuning. afr curve is all wonky. i know what i need now. a freakin pro box!
Rent me! per hour
yepo. it's goin lean up top. well, above 7200 it does. i think i need a bigger nozzle.
i need to tweak the maf before i go changing nozzles to bandaid the problem
Rent me! per hour
im still on the 3.1 pulley. hence the low torque. i can watch the tach go up faster than the boost gauge. at 4500. all bets are off. it flat gets it after that.
im going to do some maf work tomorrow on it
