long road to ruin
Old Aug 7, 2008 | 03:05 PM
  #76
WickedSS2005's Avatar
Originally Posted by Rodimus_Prime
im confused as to how your getting IAT2s less than 20 off the IAT 1
im at like 40 degrees over, im using straight dex cool also
Area, IIRC, is running straight distilled H20 during summer months. As for heat disipation = Dexcool (Good) << Water+Dex-cool (Better) << 100% Distilled Water (Best)
Old Aug 7, 2008 | 03:23 PM
  #77
BoostedYards86's Avatar
Distilled water + water wetter is the best LOL. I only have a H/E with a 2.9 pulley and I am usually only upper 120's low 130's after a very long run.
Old Aug 7, 2008 | 03:58 PM
  #78
Rodimus_Prime's Avatar
hrmm interesting i might have to give this a try
Old Aug 7, 2008 | 04:06 PM
  #79
Area47's Avatar
Rent me! per hour
actually i have not touched the aftercooler fluid since i put the front mount on the car. it is more water than dexcool, but not enough to make a huge impact.
plus there is some air flow modifications that are not visible to the average person.
:X
Old Aug 7, 2008 | 04:09 PM
  #80
invisible's Avatar
Did that heat wrap make any difference?
Old Aug 7, 2008 | 04:15 PM
  #81
Area47's Avatar
Rent me! per hour
newp. with the m62 it averaged 11-12 degree's warmer iat2 vs iat1
Old Aug 7, 2008 | 04:17 PM
  #82
an0malous's Avatar
gettin similar timing as with your m62 setup?
(p.s thanks for the suggestion about 75% meth, tried it, and got some pretty nice results)
Old Aug 7, 2008 | 04:21 PM
  #83
Super_SS's Avatar
damn nice, cant wait to see wat u can do with more fuel, and tuning.
Old Aug 7, 2008 | 04:27 PM
  #84
Area47's Avatar
Rent me! per hour
i have not touched the timing table. i need to, just to keep it on the safe side since the cylinder pressure just skyrocketed.
occasionally i know what im talking about
Old Aug 7, 2008 | 04:31 PM
  #85
yea i top 1.36 on the spark chart with ease
Old Aug 7, 2008 | 04:33 PM
  #86
You buys make me want to spend alot of money haha.
Old Aug 7, 2008 | 04:35 PM
  #87
06black's Avatar
(old piece, new one is biggar)
end thread.
muwhaha! love ya bry!
gimme a call later today if you wanna chit-chat or some ****....ya know.
  #88
Area47's Avatar
Rent me! per hour
i don't
remember. you **** your maf up on the scaling side of it. this will skew a lot of things in the end.
im sitting about 1.20 on the g/cyl
Old Aug 7, 2008 | 04:36 PM
  #89
an0malous's Avatar
that doesnt really indicate cyl press though...
you can change things and run in all different places on that table if you want to.
Old Aug 7, 2008 | 04:38 PM
  #90
Area47's Avatar
Rent me! per hour
end thread.
"blah blah blah im compensating for having a small dinger, blah blah blah" thats all i read
lawl
::runs::
i'll give ya a call when i get off work
Old Aug 7, 2008 | 04:49 PM
  #91
BlackSS/SC's Avatar
exactly
Old Aug 9, 2008 | 12:23 AM
  #92
Area47's Avatar
Rent me! per hour
17-18 psi.
street tune
332/261
boost doesn't come in hard till 5k. hence the low torque. damn 3.1 pulley
dyno tune. ***** out
342/267
comes out to be 393 at the crank going of a 15% draw
based this off my 290/257 m62 run.
street tune is at 19-20 degree's of timing.
dyno blast runs are not to be published
graphs to come later when i get em e-mailed to me
Old Aug 9, 2008 | 12:24 AM
  #93
lsjwannabe's Avatar
haha told you
Old Aug 9, 2008 | 12:29 AM
  #94
hoffa's Avatar
wow
nicely done sir
Old Aug 9, 2008 | 12:30 AM
  #95
Area47's Avatar
Rent me! per hour
the first pull was at 10.3 afr. that was 320 out of the box. then leaned it out from there. i do need to do some major maf tuning. afr curve is all wonky. i know what i need now. a freakin pro box!
Old Aug 9, 2008 | 12:34 AM
  #96
lsjwannabe's Avatar
5gph nozzle?
Old Aug 9, 2008 | 12:36 AM
  #97
Area47's Avatar
Rent me! per hour
yepo. it's goin lean up top. well, above 7200 it does. i think i need a bigger nozzle.
i need to tweak the maf before i go changing nozzles to bandaid the problem
Old Aug 9, 2008 | 12:38 AM
  #98
lsjwannabe's Avatar
yep just what i was going to post. I went to the 7gph nozzle on the 2.5"
Old Aug 9, 2008 | 12:39 AM
  #99
Area47's Avatar
Rent me! per hour
im still on the 3.1 pulley. hence the low torque. i can watch the tach go up faster than the boost gauge. at 4500. all bets are off. it flat gets it after that.
im going to do some maf work tomorrow on it
Old Aug 9, 2008 | 12:41 AM
  #100
scampbell's Avatar
thats some awesome numbers man hope i can afford a harrop swap next year... maybe ill buy one used like you did.
