A look at the Intercooler pump.( Lots of pics)
Old Feb 23, 2010 | 02:16 PM
06yellowburdSS's Avatar
What signs are we looking for as to determine whether or not our IC pump is failing, or has failed?
Old Feb 23, 2010 | 02:54 PM
phatnackySS's Avatar
Originally Posted by harryresh
while i was pulling the end of the motor apart, a bent up washer looking piece fell out of the motor. where does this go?
post a pic if you can.
Originally Posted by shadowfaxss
Mine looked this bad as well when I took it apart. Replacing the brushes would most likely not last that long. The comutator/armature that the brushes contact are severely worn as well (as illustrated in the fifth picture).
This is true , the first time i pulled the motor apart the commutator was fine , the brushes were just worn and dust was keeping them from sliding and making contact. so i cleaned it and put it back together , once i found brushes (some 5k+ miles later ) one of the bruises had turned sideways and scored the commutator. so for some this fix will work, for others if it looks like mine did , don't expect it to last long, so far mine is still going strong.
look at the intercooler filler neck, if its bubbling churning while the car is running then its working.
Last edited by phatnackySS; Feb 23, 2010 at 02:54 PM. Reason: Automerged Doublepost
Old Feb 23, 2010 | 03:34 PM
Illini_06SS's Avatar
Meh. I'll just spend $100 and get a new motor...
That seems like a lot of work and with a 90% chance of massive frustration.
Old Feb 24, 2010 | 01:59 PM
harryresh's Avatar
[QUOTE=phatnackySS;4713180]post a pic if you can.
Here is a pic of the "washer" that fell out of my intercooler pump motor while taking it apart...
Old Feb 24, 2010 | 03:05 PM
[QUOTE=harryresh;4716360]
That is odd i dont rember seeing anything like that
Old Feb 24, 2010 | 05:00 PM
troyss's Avatar
How can I tell if its dead or not? the IC pump
Old Jul 13, 2010 | 06:56 PM
SprChrg4Life's Avatar
When I tried to bleed my intercooler system for 3 hours after a OTTP exchanger install, it finally dawned on me that my pump must not be working... bench tested it, nothing! Damn you pump!!
This how-to helped me save $$ which is always a good thing. Excellent, clear cut info and great pictures. My dad and I had a blast reconditioning it... being a retired electrician, he was totally into rebuilding the motor. Anything involving electricity is of course right up his alley heh. Infact he wanted to rewind the armerature so it'd be more powerful
Thanks a million!
Old Jul 19, 2010 | 12:16 PM
NinjaHampster's Avatar
sub'd
whats the part number? i tried using the ones from the pic's but no luck and the bosch website was no help. also is this a dealer item only or can you get one at autozone?
Last edited by NinjaHampster; Jul 19, 2010 at 12:16 PM. Reason: Automerged Doublepost
Old Jul 19, 2010 | 03:54 PM
Originally Posted by NinjaHampster
sub'd
I'll have to look around for it . every ace has different parts , i went to 3 in my area before i found ones that fit.
Old Jul 19, 2010 | 04:01 PM
appreciate it
Old Jul 19, 2010 | 06:02 PM
  #36
HunterKiller89's Avatar
sub'd
autozone can order one for you...
ask them for the intercooler pump from a cobaltss, ford lightning, 03-04 mustang cobra, etc.
They can order oem parts, and its an oem pump on several cars
06MetallicBalt
Jul 20, 2025 08:47 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
