Looking at the ZZP Mid-length header/dp combo
I think I'm going to go with that and maybe their catback system unless I can find something that is 3" sounds good and gives the same or better performance(was thinking of having a muffler shop price out a catback system...if anyone knows of any good ones in Michigan around Detroit Id appreciate the info to contact them) I notice on this combo for option 4 extra 02 bung for wide band or a 02 bung and plug....not sure which one I would need...I do plan on getting ZZP's Stage 3 kit after the exhaust. Thank you in advance =D
get it with the wideband o2 sensor. if your going to be running a stage 3 u should be monitoring to make sure ur not running too lean or rich. it also allows for a custom tune afterwards as tuners pretty much need a wideband to tune off of. plus for the time being that u dont have a wideband u can just buy the $4 plug for it
I have been looking at all their work, reading testimonials and speaking with Dan....they seem to know whats up for exhaust systems =D. I want to get their custom tune once I'm all said and done with upgrading I see some outrageous increases in numbers....anyone have their tune from here on the LSJ and if so what mods are you currently running?
i had to use 2 gaskets on mine, mostly because the flange itself is warped, perhaps they should mill them flat before shipping, might solve alot of issues, or better yet get a 3 bolt flange on it!
i haven't had a problem with the header/dp or the stage 3. couldn't be happier with my choice to go with zzp.
not that any of them is all that hard to install. zzp doesn't send any directions. just givein u a heads up
