Loose radiator, heat exchanger?
So I was at a autocross event last weekend and I opened my hood between my runs to let it cool down some and I went to wipe something off the top of me radiator through that little hole and noticed the package of the different cores can move about a inch or so foward and backwards. I'm going to take it to the dealer but I wanted to see if anyone else can do this with theres or if mine is just loose. It looks like it is held up with some pins going through a rubber pieces that may eliminate the agressive shaking, bumps, or something. Just doesn't seem like it should move that much
A full inch seems like a lot for the heat exchangers to be bouncing around back and forth. Definetly have it checked out. But who knows, these cars a strange as hell. Maybe it is normal???
Problem solved the bracket had came loose a little bit. The three pieces ride on four bushings and the top two were not all the way seated. Took less the 30 minutes at the dealer.
n20saturn
Sep 30, 2015 12:26 AM
