Loose radiator, heat exchanger?
Old Sep 15, 2005 | 09:36 AM
Chevypowered's Avatar
So I was at a autocross event last weekend and I opened my hood between my runs to let it cool down some and I went to wipe something off the top of me radiator through that little hole and noticed the package of the different cores can move about a inch or so foward and backwards. I'm going to take it to the dealer but I wanted to see if anyone else can do this with theres or if mine is just loose. It looks like it is held up with some pins going through a rubber pieces that may eliminate the agressive shaking, bumps, or something. Just doesn't seem like it should move that much
Old Sep 15, 2005 | 12:51 PM
BullDog71ss's Avatar
A full inch seems like a lot for the heat exchangers to be bouncing around back and forth. Definetly have it checked out. But who knows, these cars a strange as hell. Maybe it is normal???
Old Sep 18, 2005 | 10:32 AM
Problem solved the bracket had came loose a little bit. The three pieces ride on four bushings and the top two were not all the way seated. Took less the 30 minutes at the dealer.
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
Sep 30, 2015 08:18 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
