loosing boost
Old Dec 20, 2009 | 09:43 AM
mrbelvedere's Avatar
yea i got it at the dealer they had to order it un hook the vac hose to it and se if ti holds boost if it does replace the solenoid
Old Dec 22, 2009 | 05:11 PM
BlueSS/SC's Avatar
Thanks, im going to try that
Old Dec 22, 2009 | 07:16 PM
jonathan923's Avatar
hey man i had the same issue along time ago and it was specially at high rpms i would go from like 17psi down to like 11-12ish and lose alot of power...my problem was that the water pump was bad and the car was running really hot so the computer was cuttin boost drasticaly cuz of the hot temp. keep us posted...
Old Apr 1, 2010 | 06:29 AM
BlueSS/SC's Avatar
Alright lm bring this back to life cause the problems still continues...
So l intalled my interceptor and my pump is working, IAT2 goes does down once l start driving
but now l know l knock, and lm misfiring like crazy at idle. So im in the markert for a better tuner!! The guy that tuned me is a useless tool
Old Apr 1, 2010 | 07:04 AM
Chevycobaltss3's Avatar
Well about your idle, with 60s bro youll have a type of mifire, it is really hard to tune them because of there short pulses. one thing to for your knock, see why, fuel, timing, iat2z. but more then likly it is your timing. let us know how it goes
Old Apr 1, 2010 | 10:15 AM
rnjmur's Avatar
Yeah, tuning the misfires out when you have 60s is almost impossible due to their min short pulse width. As long as it doesn't misfire when driving you should be fine.
As far as knock goes, were you tuned with a wideband? How much timing is being commanded when you are getting knock? Alot of times with a 2.8 you have to run a little richer due to the extra heat it is creating unless you are running meth.
Old Apr 1, 2010 | 11:10 AM
exactly i second that one, i run a 11.3 at top end and i run a 12.2 at bottom end. but check timing, i bet since it got warmer you started creating knock because your iat2s and high timing. or plugs could be bad
Old Apr 1, 2010 | 06:21 PM
BlueSS/SC's Avatar
I was thinking about changing the plugs, the misfire is only at idle but l have had a few CEL while l was driving
I was tuned with a wideband, l have been re-tuned by this guy at least 3-4 times..Im not sure what my timing is set at??
Im getting re-tuned april 17 or 18th so we will see he can fix it, plus im installing my h/e and dual pass asap
Keep you guys posted
Thanks for your ideas
Old Apr 7, 2010 | 06:58 AM
BlueSS/SC's Avatar
Alright! Im fed up with my tune and how these 60's run so im going gm stg 3... For me its the best solution
Old Apr 7, 2010 | 07:12 AM
shroogis's Avatar
You could order an OTT pcm for your mods. I know canned tunes aren't "ideal", but it's pretty damn good!
Old Apr 7, 2010 | 10:49 AM
  #36
Backdrift's Avatar
Everything rnjmur has said so far is 100% true.
Old Apr 9, 2010 | 06:04 PM
  #37
BlueSS/SC's Avatar
So l found a trifecta dealer near by... lm heading in that direction and we'll see how it goes
turbochargedss2012
Sep 20, 2023 12:17 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
