Loss of Power with Exhaust
yea, like others said i bet something not on right.
Original Hayden Fanatic
I already start a thread on this some time ago
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/exhaust-gain-loss-22500/
That is really strange, when i first got my exhaust installed i thought i lost some low end torque, but it was just a mind trick, the gmpp exhaust was so much louder i didnt realize i wasnt stepping on the gas hard. In order to get noise like that on the stock exhaust u wouold hve to give it pretty decent amount of throttle. Then i opened her up and it pulled hard as *****. So i dk man mabey something is wrong with your exhaust, or mabey its all psychological.
Well 3" is way to big for the amount of flow the engine produces, so at low load when under vacuum, the engine will be struggling to push all its exhaust out. I know that sounds crazy, but exhaust to large has more room for the exhaust gas to cool down, thous flowing slower.
It also shows you how to place them in the instructions that come with the exhaust
They should be off to one side, preferably with the nut facing the ground that way its easy to tighten. If you look how the recieving flanges are cut on the exhaust the clamp needs to squeeze the top and the bottom together, therefore your bolt needs to be on one side, not the top or bottom.
I figured the car would be faster just from the disproportionately lightened wallet from their uber-expensive exhaust systems. something must be wrong.
I mean, most mods power comes from how much you spend on them , so the GMPP should be the best.
Yeah, I'm going to have to look it over tonight. I'm disappointed right now. I kinda wish I had my stock exhaust back on right now. It pulled nicer.
Other than a custom I believe GMPP is the least expensive out of all the exhausts.
I just installed my GMPP performance exhaust today also and i noticed the same thing, along with a clunking from the front end when i leave a stop and am turning. I kind-of figured there would be a little loss or low end torque because of less restriction but its a little more than i figured.
Weird how you feel you lost power. Even the Administrator got like 12WHP out of it.
https://www.cobaltss.net/forums/show...ight=gmpp+dyno
