lowered with 3" exhaust bangin on rear bar
Old Apr 14, 2011 | 10:39 PM
  #51
sjc0013's Avatar
Window Licker
Nice find Dayta, I will have to do this when i finally get some springs
Old Apr 14, 2011 | 10:46 PM
  #52
Red2.4SS's Avatar
I'm taking my car in tomorrow to get the exhaust hangers fixored so that mine stops banging and rattling off of the suspension bar. Although I like the heater hose idea, and that may be part of my solution if the exhaust shop cant get it to stop.
Old Apr 15, 2011 | 02:31 PM
  #53
countrySS's Avatar
Originally Posted by Dayta
i did this yesterday but noitced that the exhaust before this mod was hitting the body of the car just as much as it was the rear crossmember
Old Apr 15, 2011 | 02:37 PM
  #54
ecot3c inside's Avatar
You my friend are a GENIUS.
Old Apr 15, 2011 | 02:40 PM
  #55
countrySS's Avatar
thanks but wasn't my idea i saw Dayta post the pic so thought i give it a shot
Old Apr 15, 2011 | 09:45 PM
  #56
Red2.4SS's Avatar
Got some new mounts and a bit of pipe reworked on my by Clear Image today. Very nice. Even over speed bumps there is no contact with the suspension bar with my 3" exhaust.
Old Jul 3, 2011 | 12:37 PM
  #57
xbobbitox's Avatar
MPX does the same thing I had to shorten mine because the bend wasn't over the beam correctly it was too far out, shortened it now I'm straight, I'm only an 1.3" lower in the rear too
Old Jul 3, 2011 | 12:53 PM
  #58
dandaman15's Avatar
I wonder would would happen if I get an exhaust... Im an LS and I am already close to the stock 1.75in or so piping. Im also lowered close to 4in in the rear. When the car is sitting in the driveway I have about 1.5in of clearance from the pipe to the beam. I have yet to actually make contact with it however. I want the Vibrant system bad though.
Old Jul 3, 2011 | 02:08 PM
  #59
xbobbitox's Avatar
You'd prolly hit easy then^^^ is it 2.5"
Old Jul 3, 2011 | 02:59 PM
  #60
G11's Avatar
G11
mine doesn't hit on the bar...it hits on the evap only time is does tho is when it comes off of one of the hangers...
Old Jul 3, 2011 | 03:44 PM
  #61
xbobbitox's Avatar
It's a stupid thing to happen, it might happen, and it might not, so you will just have to try it either way there is a fix just bend the pipe a little and see how it works
Old Jul 25, 2012 | 11:46 PM
  #62
tru2nrtt777's Avatar
I am having clearance issues, I traded my 2.5" for a Hahn 3" and now my exhaust at the lowest point(the elbows that go from the middle, to the side, then to the rear) is only 2.25" off the ground... My front pinch weld height is 2.75 and my rear pinch weld height is 3.25 for reference... I heard it tapping the rear axle once when I had a ton of crap in the trunk but not since. Unfortunately one piece of the piping is touching the body so I don't think I can raise it more...
Old Jul 26, 2012 | 03:19 PM
  #63
Tjolley's Avatar
Im running a zzp 3" catback..i have h&r springs...i have no clearance problems
Old Jul 26, 2012 | 07:08 PM
  #64
H&R's are still at least an inch above(when referring to their lower springs).
Old Jul 26, 2012 | 09:27 PM
  #65
Tjolley's Avatar
Hmm must be the rear cuz my front is lower than my friends with sportlines..but i ges its all about the rear anyways.
Old Jul 27, 2012 | 12:14 AM
  #66
sjc0013's Avatar
Window Licker
I'm on H&R's with the Hahn 3" and haven't had any issues, I was very surprised
DANRICKARD
Oct 1, 2015 12:08 AM
nathan112i
Sep 30, 2015 07:12 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
