ls4 tb and cat delete dyno results.
Old Jan 14, 2012 | 02:22 PM
100% METH's Avatar
The LS4 gains more than just 4 ponies... this topic has been beaten to death
movingswiftlythef#%konnow
Nice gain OP
Old Jan 14, 2012 | 02:25 PM
RooTBeeR's Avatar
lol it has, i was actually gonna hit you up to see what you netted from it, i couldnt remember
Old Jan 14, 2012 | 02:28 PM
100% METH's Avatar
10whp without changing a single airflow/fueling/timing table. Only thing changed was the scaler.
The gain was through out the entire power band
Old Jan 14, 2012 | 02:30 PM
RooTBeeR's Avatar
you only tested it though, right? you dont use it any more?
Old Jan 14, 2012 | 02:34 PM
100% METH's Avatar
non sense... why would I downgrade? I run it with my 2.5 pulley on the ported m62.
Old Jan 14, 2012 | 02:40 PM
BLue NoTe's Avatar
I'm scared of the 2.5. Plus Id still like to hit 7k rpm. I bet the torque is good though
Old Jan 14, 2012 | 02:46 PM
RooTBeeR's Avatar
hmm, maybe im thinking of jr's car then one of you recently were swapping tb's but i think just for testing/gains
wonder how hard it'd be to get the stock cai to work with the ls4
Old Jan 14, 2012 | 02:53 PM
100% METH's Avatar
it's still slow
the m62 is pathetic
but yes... torquey for a m62.. spins 2nd at will.. on a cool night
we tossed the ls4 on his car with the tvs on it, but didnt dyno it. Didn't have time
Old Jan 14, 2012 | 04:04 PM
goeckeritz123's Avatar
Originally Posted by zfissette
the parts were the change to be sure, the car was tuned last week, put down 258, swap the parts and dial her back in 273. i just hope when i move to tvs that she breaks 300.
you should for sure break 300 whp with tvs
Old Jan 14, 2012 | 04:09 PM
im thinking of swapping to the ls4, but realy how bad is the trottle responce?
Old Jan 14, 2012 | 04:31 PM
  #36
BLue NoTe's Avatar
Apparently its all in the tune, but I'm no tuner so I have no specifics
Old Jan 14, 2012 | 04:46 PM
  #37
100% METH's Avatar
Its more alive compared to stock. I have zero gripes driving w/ this throttle body. I personally cannot stand driving on the stock one. The car feels lazy and unresponsive when on the stock throttle body.
scaler: 4950
setup a custom histo to add [sens.114]+[sens.116]/2 (Use the MAF vs output freq. table)
- This will add your LTFT AND STFT and divide by 2.
- Simply multiply the hit cells by % 1/2 into your MAF
Whalaa...
Old Jan 14, 2012 | 06:07 PM
  #38
RooTBeeR's Avatar
now, why do you have it divided by 2?
Old Jan 14, 2012 | 06:36 PM
  #39
InfraRedline's Avatar
To get an average. Add both numbers and divide by 2 to get an average of the combined sum.
Old Jan 14, 2012 | 07:04 PM
  #40
RooTBeeR's Avatar
i see...i have only tried to use my ltft + stft histo once. it was set up by 04Redline(shaun) and no /2 i'll have to change that
Old Jan 14, 2012 | 07:23 PM
  #41
Speedytec's Avatar
Huh? Why average the (LTFT + STFT) ?
When LTFT = -10 and STFT still subtracts -5 at one point to get a 14.7AFR, theoretically that point should be corrected then by -15.
But ulimately it doesn't make that much difference for tuning; averaging just lowers your correction numbers by 1/2. Like multiplying by %1/2 does...
Old Jan 14, 2012 | 07:37 PM
  #42
RooTBeeR's Avatar
i use this a lot unless something is WAY off
Old Jan 15, 2012 | 06:43 AM
  #43
100% METH's Avatar
The point is so you can make finer adjustments. It's very easy to over shoot cells 1.6-2.4...
Old Jan 15, 2012 | 07:48 AM
  #44
hhrfreek's Avatar
I was running the LS4 tb and took it off. I thought it was a pita. I drove it for a summer so I had plenty of time on it. Gains are only going to be made with a small pulley or a TVS. The throttle response feels awesome, I will say that. But response doesn't mean your making more power, your just getting thrown into boost very quickly. The car runs way better on the LSJ tb imho.
Originally Posted by hhrfreek
I logged 167kpa with the LS4 tb and 165kpa with the LSJ. The slight gain is not worth it. Also the smaller tb allows for steadier tuning and keeps the car out of boost in the mid range.
Originally Posted by Sharkey
the ls4 throttle body isnt worth it from what i read, not unless you have an eaton tvs. and what you logged could be the difference in barometric pressure between the 2 logs. with an lsj you can monitor sc inlet pressure (thats the second map sensor on the s/c neck), if it shows vacuum under heavy throttle you have throttle body or intake restriction. most people see very little vacuum, the end result really is the larger throttle body doesnt do much.
This.
Old Jan 15, 2012 | 10:34 AM
  #45
Chevycobaltss3's Avatar
Ok so i was able to look at ure tune. This is what i seen, he is not scaled for the ls4 throttle body meaning he was still in the stock scale, timing needs work, they did tune in the maf calibration.. so i did change the tune up a little with john. So get with john soon so you can properly be tuned
Old Jan 15, 2012 | 12:17 PM
  #46
To be honest on the LSJ I usually just get a longer log and use the LTFT to get things in check unless its way off to begin with. I just like making smaller adjustments rather than possibly having to work backwards. Just my weird way lol
Old Jan 15, 2012 | 12:27 PM
  #47
bobbyjohn681's Avatar
Brought my cobalt down to SMG and swapped out her stock tb for a euthanasia ported and polished ls4 and changed her zzp catted downpipe for a zzp offroad down pipe. Net gain 15 hp and torque. car runs well with excellent throttle response, only a little rasp. will post dyno pic as soon as this site will let me.
Pictures by zfissette - Photobucket
is the ls4 tb setup any different as far as "streetablilty"?
Old Jan 16, 2012 | 12:57 AM
  #48
microgab's Avatar
This topic is getting interested...if we can get 10whp out of this, it would be a awesome mod! With a tvs
Old Jan 16, 2012 | 01:04 AM
  #49
Killa SS's Avatar
is the LS4 TB worth it for us LSJ turbo guys looking to push more the 450whp?
Old Jan 16, 2012 | 07:35 AM
  #50
hhrfreek's Avatar
Bigger isn't always better...
https://www.cobaltss.net/forums/2-0l...esting-171566/
Did anyone see what I wrote a few days ago? I do not have an LSJ so I cannot monitor the map sensor on the SC, but if I did that would be the indicator of whether or not I would upgrade to another size...or simply port your existing LSJ TB. Does anybody have dynos of TB swaps before/after with their other mods listed?
