is the ls4 TB worth it?
Nobody ever making big power has needed the LS4 throttle body... Not S/C, nor custom turbo...
You may gain a little power under the curve down low, but up top end I believe I've heard it to actually lose power.
The driveability sucks. You can learn to drive around it, and get used to it, but it still isn't 'good'.
The throttle body is not a restriction... There is no need for a larger one... Nobody has ever offered proof that is it 'better'. Rebel tried to the one time years ago, and it showed about 10hp down low, but still wasn't good for the top end.
It basically opens the throttle blade 30% more over the stock LSJ TB, so just push the gas pedal more lol. High RPMs, you *aren't* maxing the airflow of the stock LSJ TB...
I drove one on the M62 and the TVS for over 2 years, and all it did was shorten 1st gear, and make the car super touchy.
Spend the money elsewhere... My $.02
I Just bought a an s4 throttle body and the reason is that my thottle body sensor is going out cause my car keeps doing the engine reduce power. Anyways quick question does the ls4 tb need a adapter plater or does it just bot on. What i mean is do i nee to modify it or willl it just go on. Any help would be appreciate.
I have to dig up my dyno sheets, but that isnt entirely true. While i cant speak for the LS4 TB, there ARE gains to be had w/ even a slightly enlarged or ported TB. I did a before and after dyno of my SC and gains were about 5whp/3-4lbft on a stock balt (not 100% on the tq #)...across the board...not just under the curve...
And drive ability was FLAWLESS, better than stock. I didnt want to give the prototype back
The juice isn't worth the squeeze.
The ~5hp/trq are normal dyno fluctuatins which could be caused by any number of things. The key word of your finding is also 'slightlty' enlarged, as that should help, but something like the LS4 is much larger and will likely hurt things. There is a point of diminishing returns.
but i get what your saying. Wasnt starting a pissing match, just saying there ARE dyno proven gains to be made...not with an LS4, but a properly designed one.
i wish we could have dyno'd it on a stage 2 for example...
No, 3 runs done before, 3 runs done after, all showed 5 hp gains, so it wasnt a dyno fluctuation
You wont need to increase your intake manifold though, your SC will take care of that. A larger throttle body will just make it eayer for the SC to draw air in and pack it into the intake manifold.
But if your gona want a larger TB, then you're probably best off getting the 3" ZZP intake, as well as a SC that has a larger input side. Each of wich would help the others maximise the poltentioal gain.
Hey quick question my tb sensor is messing up i have a 1s4 tb. So my question is if i swap my tb how would my car drive or will it be drive at all without getting a new tune i'm on stock tune?
What it does do is let in about 30% more air per given throttle position. This, when matched with fuel (i.e. good tune - maf), creates more power down low. (More air plus more fuel = more power)
Keep in mind that if you are on the stock M62, you will need a spacer designed for this LS4 upgrade, or you will need to grind out the inlet of the M62 in order to even have the throttle blade open. You will also need a coupler to connect the larger opening of the throttle body with your intake.
If you have an aftermarket blower (i.e. TVS), the inlet of the supercharger may be big enough already, so a spacer/modification may not be needed at all. For example, the TVS was actually designed with the larger LS4 throttle body in mind, so no spacer is needed.
Wow, there is a shitload of misinformation in this dead and old thread...
People should really search around and read up on stuff from 'back in the day'. Start with RAW's testing of the LS4, up until everyone who ever made big power on a blower not using the LS4... Bigger isn't always better.
But I digress, I sold my LS4 TB over a year ago, and I don't even own a Cobalt anymore...
Is there something that I posted that was considered misinformation? Please elaborate...
I never said that it would give you big power. Just down low power, or, like stated, "power under the curve."
Haha aight boss. I guess that's why I've moved on to bigger and better things. Just a hint, I represent the .01% demographic on here not the others...
The original question was whether or not the LS4 TB was worth it, and the short answer is 'no'. Nobody has proven otherwise, and the attempts have been just as unfounded as those that say otherwise. Now you two are some of the ones who may know what you're talking about, but unfortunately you can't speak for the others.
Like Bryan told you earlier, prove it... I'm out.
