LSJ 2.9 Pulley
Old Jan 7, 2016 | 12:23 PM
charly406's Avatar
LSJ 2.9 Pulley
i want to know if i can run 2.9 pulley with stock belt and stock tensioner?
thanks
Old Jan 7, 2016 | 12:31 PM
Haven07's Avatar
Your gonna want the stage 2 belt, it'll be a tight fit
Old Jan 7, 2016 | 12:44 PM
Staged07SS's Avatar
Administrator
Administrator
You will need a GMS2 belt.
it will slip on with the stock belt.
Old Jan 7, 2016 | 04:13 PM
bubba_jay's Avatar
Or just buy the adjustable tensioner and done with it.
Old Mar 7, 2016 | 12:51 AM
xRedrumisBack's Avatar
With a stage 2 belt I have had my 2.8in pulley slip, do not remember if it ever did on a 2.9. I recommend you get adjustable tensioner though. A sudden drop in boost during a pull because of slip does not make a happy motor. Plus you can set your self up for good tension on any possible future setup, stock, 42s on a 3.0-3.1, 60s on a 2.8-2.9, 80s+E85 on 2.7, TVS etc.
Old Mar 7, 2016 | 07:16 AM
Staged07SS's Avatar
Administrator
Administrator
The S2 belt is good down to a 2.7 w/o issue.... If you had slip, it was more than likely due to the aftermarket pulleys ribs.
I've always noticed smoothflow, and other aftermarket pulleys do not match the stock/gm pulley rib dimensions.
Old Mar 7, 2016 | 08:01 AM
blueLNFftw's Avatar
Stage 2 belt and OEM tensioner.
2.7 pulley all day on that set up.
Old Mar 7, 2016 | 10:50 AM
Never thought about the pulley ribs, guess it's safe to go adjustable tensioner for the extra tension though.
Old Mar 7, 2016 | 10:52 AM
blueLNFftw's Avatar
Safe?
It is not needed.
Old Mar 7, 2016 | 10:57 AM
I have had my belt slip during a pull before so I'm trying to keep that from happening again.
Old Mar 7, 2016 | 12:11 PM
blueLNFftw's Avatar
Spend the money on a new belt then instead of tightening an old one.
Old Mar 7, 2016 | 12:16 PM
Belts only about 9months old, it may be possible something else is going on. I am going to check the tensioner pulley bearing to make sure it isn't worn out and causing resistance. Belt has been good for about 2 weeks though so I might just leave it be.
Old Mar 7, 2016 | 12:18 PM
blueLNFftw's Avatar
I would check all of the pullies then.
I had a 2.7 on mine and made 279whp; never had a slip issue once. Smooth flow pulley. A good belt and smooth pullies are essential.
Old Mar 7, 2016 | 12:20 PM
I will, Thanks! Btw, 279whp is pretty impressive, were you using meth or E?
CAMJAG
North East
Mar 16, 2016 02:48 AM
fonzie1991
Feb 3, 2016 08:07 PM
sS07NA
Dec 26, 2015 05:38 PM
Legion
Dec 23, 2015 03:45 PM
izcain
Dec 21, 2015 01:33 AM
