LSJ in 2000 J Body
Old Aug 21, 2006 | 12:29 AM
tube's Avatar
LSJ in 2000 J Body
My friend recently purchased an LSJ with 5000 miles on it because it was a great deal (800$). He has an '00 sunfire project car with the 2200 and I'm wondering, how hard would it be to mate the LSJ with the getrag upto the '00 j-body?
Is it even do-able?
Old Aug 21, 2006 | 12:49 AM
CobaltSonOfS.A.M.'s Avatar
Should work, 02-04 j-bodys had the 2.2 ecotec, at most it would take the engine cradle from one of them, as for the trans, donno ask mantapart.com they might be able to help,
Old Aug 21, 2006 | 04:57 AM
IonNinja's Avatar
?? he just said it has the 2200 motor, not the ecotec
but if the 2200's can swap to 2.2 ecotec's its gotta be doable. but what about the trans?
Old Aug 21, 2006 | 10:39 AM
don't know about the trans, yes the ecotec 2.2 should be able to swap into the 2.2 ohv, but he may have to get the engine cradle from a 02-04 that had an ecotec.
Old Aug 21, 2006 | 10:43 AM
distillion's Avatar
ive seen a 03 sunfire with an LSJ on jbody.org a year or 2 ago.
Old Aug 21, 2006 | 12:06 PM
phlatcav's Avatar
The LSJ WONT go into the jbody because of the tranny being to wide I belive. Tell your friend to swap in a 2.2 ecotec and use the supercharger from that lsj. The get the ecu reflashed at the dealership. I know it is possibal to swap the LSJ head onto the 2.2 but you have to make a cut in the master cylinder to make room for the cam sensor.
Old Aug 21, 2006 | 12:35 PM
distillion's Avatar
it will fit, check .org, when i had a cav i was amazed, its a pretty sick sunfire, as to hwo they got it in and running, dont ask me, all i know is that i saw it on the .org and it was at a show.
Old Aug 21, 2006 | 06:06 PM
airtonics's Avatar
It won't swap, I already tried after throwing a rod in my 2.2 with the 2.8 pulley at the JCO Jbody bash.
Anyways, most differences can be worked around. I had them all done, however when I tried swapping the oil pans I noticed the main problem. The crank on the 2.2 has 7 marks on the crank for timing, the 2.0 has probably 100. If he wants to swap the 2.0 motor into his sunfire he will need every piece of wiring/computer from the cobalt/ion or a full stand alone.
I really wanted to do this swap, would have been great
Old Aug 21, 2006 | 07:32 PM
distillion's Avatar
thats really strange, i saw it i swear i swear, musta been a sunfire GM built for shows and worked their magic with...
Old Aug 21, 2006 | 07:51 PM
A full ecu, harness, engine and cradle swap would probably do it with a beefed up 00-04 trans.
Old Aug 21, 2006 | 07:55 PM
articzap's Avatar
its not to wide...the car is just to narrow. where theres a will theres a way. im sure it can be done and would well worth it
Old Aug 21, 2006 | 08:11 PM
joeworkstoohard's Avatar
here's a silly question... if GM racing can use an ecotec on an impala automatic... couldn't that be made to fit?
Old Aug 21, 2006 | 08:20 PM
If the Impalla auto will swap into the J-body, yes, but if not, well I'm sure there are beter choices if you got to cut to make it fit.
Old Aug 21, 2006 | 08:25 PM
distillion's Avatar
iv seen a v8 in a j-body, a yellow one, or a northstar in a lil golf, you have money, it can be done.
Old Aug 21, 2006 | 08:50 PM
try a 454 in a 02 cavi, Last year it had a blown small block, see the hole cut in the hood? Thats where the blower stuck out the hood.
Old Aug 21, 2006 | 08:54 PM
distillion's Avatar
there she is, looks like my old cav, minus the beast under the hood lol
Old Aug 22, 2006 | 03:25 PM
phlatcav's Avatar
Why not just build the bottom end on a 2.2 eco and put the charger on it. You CAN make just as much power with the 2.2 as the 2.0 if you have a strong bottom end.
Old Aug 22, 2006 | 03:31 PM
distillion's Avatar
ya, with a nice build and set up the 2.2 eco is pretty sick and responds pretty well to mods.
Old Aug 22, 2006 | 04:48 PM
Check out mantapart.com I swear they have all sorts of **** for the ecotec, forged and billet internals, ported heads, cams, mainifolds, intakes, ect.
Old Aug 23, 2006 | 04:15 AM
phlatcav's Avatar
I would not advise buying from Mantapart. Way to many Jbody owners have been screwed by them, some of my friends infact ordered some rockers and cams and never got a thing! A couple people have had some luck ordering COD but that 2 out of a lot .
Turbotechracing.com
Carcustoms.net
Jbodyperformance.com
are all great places to grab 2.2 ecotec parts for sure.
Old Aug 23, 2006 | 11:01 AM
PuSha050's Avatar
just a little off topic, but phlatcav, that cavi looks really really clean
Old Aug 23, 2006 | 02:22 PM
Woodyr007's Avatar
phlatcav, that car is beautiful!!
Old Aug 23, 2006 | 02:25 PM
SSCobalt~SSZ24's Avatar
my buddy is putting a Supercharged 3.8L engine in a 97 z24 lol u can do anything with some welding!
Old Aug 23, 2006 | 02:26 PM
yep cavi's look real good when done right!
Old Aug 23, 2006 | 02:34 PM
TurboTechRacing's Avatar
I would agree with phlatcav. Swap in the 2.2 and use the supercharger. The 2.0 trans has a whole differnt mounting system than the F23 trans used on the 2.2L engine. It is possible but the 12 psi on the 2.2L would be a nice setup for a lot less work.
