LSJ in 2000 J Body
LSJ in 2000 J Body
My friend recently purchased an LSJ with 5000 miles on it because it was a great deal (800$). He has an '00 sunfire project car with the 2200 and I'm wondering, how hard would it be to mate the LSJ with the getrag upto the '00 j-body?
Is it even do-able?
Is it even do-able?
The LSJ WONT go into the jbody because of the tranny being to wide I belive. Tell your friend to swap in a 2.2 ecotec and use the supercharger from that lsj. The get the ecu reflashed at the dealership. I know it is possibal to swap the LSJ head onto the 2.2 but you have to make a cut in the master cylinder to make room for the cam sensor.
it will fit, check .org, when i had a cav i was amazed, its a pretty sick sunfire, as to hwo they got it in and running, dont ask me, all i know is that i saw it on the .org and it was at a show.
It won't swap, I already tried after throwing a rod in my 2.2 with the 2.8 pulley at the JCO Jbody bash.
Anyways, most differences can be worked around. I had them all done, however when I tried swapping the oil pans I noticed the main problem. The crank on the 2.2 has 7 marks on the crank for timing, the 2.0 has probably 100. If he wants to swap the 2.0 motor into his sunfire he will need every piece of wiring/computer from the cobalt/ion or a full stand alone.
I really wanted to do this swap, would have been great
Originally Posted by joeworkstoohard
here's a silly question... if GM racing can use an ecotec on an impala automatic... couldn't that be made to fit?
Originally Posted by CobaltSonOfS.A.M.
Check out mantapart.com I swear they have all sorts of **** for the ecotec, forged and billet internals, ported heads, cams, mainifolds, intakes, ect.
.Turbotechracing.com
Carcustoms.net
Jbodyperformance.com
are all great places to grab 2.2 ecotec parts for sure.
I would agree with phlatcav. Swap in the 2.2 and use the supercharger. The 2.0 trans has a whole differnt mounting system than the F23 trans used on the 2.2L engine. It is possible but the 12 psi on the 2.2L would be a nice setup for a lot less work.
