lsj build problem
Old Jun 27, 2020 | 12:06 AM
helle888's Avatar
lsj build problem
I am having a really rough idle problem. I just installed stage 2 zzp cams, ported head, ported intake, option B, stage 3 heat exchanger, 2.7 pulley. I'm not getting any codes and I've got a bad hesitation coming off of idle.
Old Jun 27, 2020 | 02:41 AM
blu3_v1p3r's Avatar
Who is tuning?
Old Jun 27, 2020 | 08:05 AM
helle888's Avatar
lsj build problem
nobody yet. I'm running a zzp 1.0 pcm
Old Jun 27, 2020 | 09:54 AM
blu3_v1p3r's Avatar
Who is tuning?
is the ZZP tune before of after install of cams, ported head, ported intake?
Old Jun 27, 2020 | 11:16 AM
helle888's Avatar
lsj build problem
before
Old Jun 28, 2020 | 06:27 AM
blu3_v1p3r's Avatar
That is probably your issue. You will need to tune for the combination of all those.
Old Jun 28, 2020 | 09:51 AM
helle888's Avatar
lsj build problem
ok. thank you. I did find out that my pcm is for an 06 Malibu l61 2.2 N/A. my car is an 05 cobalt ss sc lsj
Old Jun 28, 2020 | 01:39 PM
Sharkey's Avatar
i dont believe thats actually possible. the l61 uses a completely different computer, different ignition, different reluctor wheels, etc. i dont even think a 2.2l pcm will plug into an lsj harness.
Old Jun 29, 2020 | 02:55 AM
blu3_v1p3r's Avatar
Probably not, the L61 ECU will not physically plug up with the LSJ harness.... See if you can find the part number on the ECU.
Old Jun 29, 2020 | 03:21 AM
helle888's Avatar
lsj build problem
that's what I thought but that's what comes up on my buddy's scanner. the part number I wont be able to get till Saturday when I get home
helle888's Avatar
lsj build problem
I put the 2.9 pulley back on Saturday and it will stay running now but still idle very rough and when I try to rev it up from idle it Boggs down and backfires out the exhaust then revs up
Last edited by helle888; Jun 29, 2020 at 03:30 AM. Reason: the message got posted twice
Old Jun 29, 2020 | 08:33 AM
jdbaugh1's Avatar
The tune will have to be adjusted. It's silly to even try to run the car without a custom configuration other than to obtain data for the updated configuration. It's not optional. Pulley size is almost completely irrelevant at idle as the supercharger is in bypass mode.
Old Jun 29, 2020 | 02:07 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
You without a doubt need to be tuned again. The pulley, h/e, option B, and the ported intake really doesn't matter. But the cams and head will drastically change your air flow.
Who ever is tuning you will need to do a MAF/VE blend (it's how the car is stock, but many of us swapped to MAF only, as our available VE tables generally suck - especially for tuning for cams).
It is possible, actually. I have one for my car - maybe even in my car now (I can't remember which one I ended up using). The Malibu L61 used the same PCM - I seem to recall it was only the 2006... but I can't remember for sure. I figured this out like 3 years ago while looking for a back-up PCM while trying to figure out a connection issue with my HPT cable.
EDIT:
Old Jun 29, 2020 | 09:42 PM
helle888's Avatar
lsj build problem
who is good at tuning these cars. I don't have anyone yet
Old Jun 30, 2020 | 06:51 AM
blu3_v1p3r's Avatar
I don't remember too many LSJ tuners, but ZZP picked up one of the best a few years ago when they added Al McClure to their team. Also I'd imagine since they are ZZP cams, they might have pretty decent idea how to tune for them.
Old Jun 30, 2020 | 07:07 AM
helle888's Avatar
lsj build problem
awesome thank you. I will contact them directly. I appreciate all of the help
TPAYNTER
Nov 8, 2021 01:28 AM
JesterScott
Mar 28, 2016 10:27 PM
tylerman683
Jan 31, 2014 09:03 PM
gbkglenn
Aug 4, 2011 06:56 PM
fst07ss
Aug 11, 2008 10:09 PM
