LSJ Cooling Questions
Old Jun 8, 2019 | 06:01 PM
'05SSSC's Avatar
Hey guys, had a few quick questions regarding the LSJ cooling system. I ran over a dead deer last Sunday and it did a number on my cooling. Need to replace the heat exchange, radiator, inter cooler, and condenser. After stripping the front end, I found what looks like a snapped wire over the AC compressor. I was wondering if anyone knew what it was and if it looks replaceable. My second question is which is the condenser and which is the r in the picture below, and if anyone has any part numbers/sources to buy them.
Thanks a ton
Jack
Broken plug above compressor
which is the front unit, which one is the back
Old Jun 9, 2019 | 11:00 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
The one in front is the intercooler and the one in back is the radiator. The plug I don't have the answer for and no time to look through my GM manual as I am leaving to catch a plane.
Old Jun 9, 2019 | 11:02 PM
'05SSSC's Avatar
I think I already took out the radiator, it's the bigger unit that the fan is mounted to right??
Old Jun 10, 2019 | 06:42 AM
Yes the radiator is what the fan is mounted to. The stock configuration from front of car to back is condenser, intercooler heat exhcanger, radiator.
The plug looks like either the high pressure or low pressure sensor, not sure if GM has them for replacement (one would assume they do, but it's GM).
Old Jun 10, 2019 | 08:02 AM
Yeah thats the AC pressure sensor that you broke.
Old Jun 10, 2019 | 12:29 PM
'05SSSC's Avatar
I thought the lowest unit in front of all of those was also a heat exchanger? of is that just auxilary
Old Jun 10, 2019 | 01:03 PM
That is an auxiliary heat exhanger, they didnt come stock. Most of the stage kits include one.
Old Jun 10, 2019 | 01:22 PM
'05SSSC's Avatar
Thanks for all of the help guys, appreciate it. Last question I have (for now), but in order to get this cooling system up and running again, do i need to replace the condenser/that one pressure switch i mentioned above? Or can I just run the car without A/C for the time being? I dont want to replace the condenser or the switch because I dont have the needed equipment to safely and properly discharge the refrigerant.
Old Jun 10, 2019 | 01:39 PM
If the condenser is ruined there is nothing to discharge. I don't see any issues running without an ac compressor other than potentially some difficulty with defrosting the windshield.
Old Jun 10, 2019 | 01:43 PM
'05SSSC's Avatar
I thought I read somewhere I can burn up the compressor without refrigerant... I guess in the same vane, can I still run my heat then?
Old Jun 10, 2019 | 02:12 PM
Just don't run your defrost or AC so the compressor clutch doesn't engage.
Old Jun 10, 2019 | 02:16 PM
'05SSSC's Avatar
So on the climate controls, turning the dial to the defrost setting and not clicking the AC button will run my compressor?
Old Jun 10, 2019 | 02:46 PM
Yup and the recirculate activates the compressor also.
Old Jun 10, 2019 | 03:45 PM
Kolt's Avatar
unplug the broken piece from that sensor connector, cover the connector so water cant get into it, and the compressor will not turn on even if you go to defrost, recirc, or turn on the ac switch.
Old Jun 12, 2019 | 04:10 PM
Flarfignewton's Avatar
Correct, the compressor won't engage if the pressure in the system is too low.
Badbren_ss
Feb 19, 2016 05:57 PM
Badbren_ss
Feb 18, 2016 05:46 AM
ujustgotshook713
Mar 3, 2013 11:08 PM
ddawg23213
Sep 28, 2010 09:15 PM
eckow8
Oct 19, 2008 03:29 PM
