LSJ Custom Setup!
Old Feb 3, 2010 | 09:21 AM
Zach06CobaltSC's Avatar
There should be an iq test along with getting your drivers license.
Old Feb 3, 2010 | 09:23 AM
SloBaltS/C's Avatar
hold on matt im defending my car i for get on step colder ngk's as a performance mod
well then zach how bout you drive all the way to delaware and tune my piece of **** of a car then? ha ha
Old Feb 3, 2010 | 09:24 AM
rallycobalt06's Avatar
ok man. good luck with these savages!
SloBaltS/C's Avatar
Old Feb 3, 2010 | 09:25 AM
OneCOLDBIZL272's Avatar
when your down smoking off that crack pipe, be sure to let us know what its cose to rebuild your motor then you do
Old Feb 3, 2010 | 09:27 AM
SloBaltS/C's Avatar
ok guys prove me wrong.......someone find me a thread in here that says a ca lew up because of the setup i have......
Old Feb 3, 2010 | 09:32 AM
SSMOKEM's Avatar
In the past there has been speculation on running a 2.8 with 42's. Some say it's too much, seeing that the GM stage 2 complete setup maxes out or close to, 42's. Some people have no problems with it, but to run a 2.7 with 42's with an a/f of 11.3 seems a bit odd when your technically running the **** out of the 42's with a 2.8
He's asking because you might not know your car is in possible danger.
Edit: there won't be a thread, because you're the first person wacky enough to try it.... It may not be showing signs of blowing, but you are definitely stressing the engine.
Old Feb 3, 2010 | 09:35 AM
there's actually a lot of cars that have blown up from GM 42s, GM stage 2 tune & 2.8 pulley.... might not be alot of threads out there about it because they were afraid of everyone jumping them for being stupid. you really are playing with fire tho, running a 2.7 w/ 42s.... but the 42s you have flow ALOT better than the GM 42s and the ZZP tune is probably not too crazy.... so that's most likely what's keeping your car alive. if you were to go with a more aggressive tune on your current setup, trust me, your car will pop. putting your 60s back in and getting a more aggressive tune will actually be pretty nice.
Old Feb 3, 2010 | 09:38 AM
SloBaltS/C's Avatar
i believe its the way zzp tunes there ecu's not one vendor is alike in the tunes you get from them with their setups. it may just be luck of the draw with zzp running an awesome tune on their reflash's. however its not like i can just run 60 lb injectors on a stage 2 tune for example...... i cant just run 60's and a 2.7 and a stage 3 tune from zzp and wake up the next day and leave the 2.7 on and the 60's and just change the ecu out
Old Feb 3, 2010 | 09:39 AM
BLAZIN07SS's Avatar
I'm too JDM for you
https://www.cobaltss.net/forums/show...njectors+blown
Old Feb 3, 2010 | 09:40 AM
  #36
SloBaltS/C's Avatar
i wantd to go up to RPM Motorsports but donno if i can afford it yet ha ha and let them play with my car
  #37
BLAZIN07SS's Avatar
I'm too JDM for you
you need to search way back in this forum when people were running 2.3 pulleys with maf translators and afc controllers!
Old Feb 3, 2010 | 09:42 AM
  #38
Deathscythe's Avatar
You're not getting the point. one step colder plugs isn't going to help with the lack of fuel you'll experience up top. And if you think you're just 'stressing' your injectors, then you don't have any idea of what's really going on. Your 42's are static in the upper range if you actually are on a 2.7" pulley. Static means your injectors are open all the time. Not having enough fuel to mix with the level of oncoming air will cause a lean condition and a blown engine will soon follow.
Old Feb 3, 2010 | 09:44 AM
  #39
not to be a dick or anything..... because RPM is an awesome group of guys.... but they just don't have enough experience with Cobalts for me to trust them with tuning my car. but if you want to let them play with your car, give them a chance to start getting into the Cobalt scene, go for it. they really know their stuff with GM muscle, it'll be awesome to see them really get up to speed with Cobalts/Ions/etc.
Old Feb 3, 2010 | 09:46 AM
  #40
SSMOKEM's Avatar
I'm too scared to go back that far...my knowledge would decrease
  #41
SloBaltS/C's Avatar
ive heard the same thing about them as far as not doing many cobalts they did do andres TVS up there but no other place around here is there?
Old Feb 3, 2010 | 09:49 AM
  #42
have you even gone to the dyno with your car at all?
Old Feb 3, 2010 | 09:50 AM
  #43
from what i'm seeing BYT has tuned some ss/sc cobalts, not sure how many he's done tho. and then there's Tune Time Performance in Toms River, NJ... they've done hundreds of Cobalts, but a bunch of people have a problem with them, me personally.... i dont.
  #44
SloBaltS/C's Avatar
__________________
Old Feb 3, 2010 | 09:54 AM
  #45
rico's Avatar
get 60ss get a tune for them and call it a day?
Old Feb 3, 2010 | 09:55 AM
  #46
take the time and read the information which is on the net about blown motors. you'll see they all have one main thing in common.
Old Feb 3, 2010 | 09:57 AM
  #47
he already has 60s & a ZZP stage 3 tune (just needs to be put back on)
ZZP? j/k
Old Feb 3, 2010 | 10:00 AM
  #48
rico's Avatar
oh well he needs to not be lazy and put it on
Old Feb 3, 2010 | 10:02 AM
  #49
SloBaltS/C's Avatar
i will get both setups dynoed and let you all know wich set up is better and more fuel efficent and not so rich in oil that it spits all over the back of the car makin black dust everywhere
Old Feb 3, 2010 | 10:03 AM
  #50
rico's Avatar
man just go with 60s lol we know what 42s can do and what power they make. i ran 79-80lbs and still got 30mpg if i wasent stepping on it all the time and what not lol
