lsj idle problem
Old Mar 31, 2013 | 11:24 PM
codyqq123's Avatar
lsj idle problem
Ok when im decelerating in neutral the idle begins to bounce from 500-1200 rpm's and then eventually stalls out most of the time. This only happens occasionally and simply turning off the car and then back on fixes the problem. I thought it was the throttle body needing to be cleaned but it continued to do it even after it was cleaned. Could a dirty MAF sensor be causing this? Any ideas would be appreciated.
Old Apr 1, 2013 | 12:26 AM
codyqq123's Avatar
An added note, when the idles start to bounce it starts to smell like its running rich.
Old Apr 1, 2013 | 05:04 PM
M47TYB's Avatar
https://www.cobaltss.net/forums/2-0l...inally-116051/
muah;*
Old Apr 1, 2013 | 06:32 PM
codyqq123's Avatar
I already cleaned the throttle body and it still continued to do it. I reset the ECM today in case the battery wasnt disconnected after it was cleaned and it hasnt done it since so im hoping that was the problem.
Old Apr 1, 2013 | 07:36 PM
mitchk90's Avatar
I cleaned my throttle body, and map sensor. It cleared the problem up for me. Make sure your filter is not trashed ether, these cars are picky that way.
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
tomj77
Oct 4, 2015 11:39 AM
Sep 28, 2015 12:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
