LSJ Important Warning!
Old Aug 21, 2008 | 04:44 PM
  #151
DoMiStIc_RuSh_06's Avatar
But i mean to upgrade the pump to make it better.
Old Aug 21, 2008 | 04:47 PM
  #152
rrutter81's Avatar
Originally Posted by hatrickstu
go to hpt/system/fans/FAN output control vs state
1's across the top
0, then 1's across second row
0's across in 3rd
for hte track all 1's in first 2 rows
oh hell thats awesome. I didnt see a use for this until I thought about going to the track this weekend. Will be a great addition.
thanks a mill!
  #153
ShortStack's Avatar
Right.. upgrading the pump to make it better will probly cost more than a new pump itself and would be a waste of time ... imo...
Old Aug 21, 2008 | 04:49 PM
  #154
hatrickstu's Avatar
thanks a mill!
do the res mod, i swear to you its worth it. BTW your fans are going to be loud as hell with both rows at 1
Old Aug 21, 2008 | 04:50 PM
  #155
rrutter81's Avatar
yea i need to put it on, been too lazy with my interior lately. or are you not talking about option b?
Old Aug 21, 2008 | 05:07 PM
  #156
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
[QUOTE=hatrickstu;2769805]hey nice fail, and not even at 200 posts yet. we are talking about usingHPT to turn it on
i am trying to help with this info guys.
Old Aug 21, 2008 | 05:13 PM
  #157
hatrickstu's Avatar
you told us everything we have known since the day the car hit the lots
Old Aug 21, 2008 | 05:26 PM
  #158
Mr_Slobalt's Avatar
checked mine today and my pump is still going
however it took about five seconds before the pump kicked on after starting it....normal?
Old Aug 21, 2008 | 05:36 PM
  #159
hatrickstu's Avatar
yep thats the stock run time limit. probably was 10 seconds though
Old Aug 21, 2008 | 05:54 PM
  #160
Mr_Slobalt's Avatar
I might try your reservoir mod....cheap and effective I guess lol
what's a few bucks?
Old Aug 21, 2008 | 06:27 PM
  #161
rrutter81's Avatar
k i musta missed the reservoir mod
Old Aug 21, 2008 | 06:32 PM
  #162
Mr_Slobalt's Avatar
yay or nay to this mod?
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/heat-exchanger-fans-switch-mod-68621/
Old Aug 21, 2008 | 06:34 PM
  #163
rrutter81's Avatar
Originally Posted by Mr_Slobalt
endorsed
Old Aug 21, 2008 | 07:03 PM
  #164
Tomtwtwtw's Avatar
By enabling both to be on with accessory power, you are doing essentially the same thing with HPT.
Old Aug 21, 2008 | 07:30 PM
  #165
bobby71189's Avatar
what top are we suppost to open and what am i looking for??
Old Aug 21, 2008 | 07:35 PM
  #166
jasz71's Avatar
Hello Gang, Thank you "Psykostevo"!!!! I opened my hood and looked at the filler neck, saw barely any water/coolant. I opened the cap and rush of air came out and the fluid rushed to ok levels. I started the car(cold) and watched the filler neck, nothing... I looked at the resevoir and couldnt tell thier either. So i looked up info where that damn part is and took a long screw driver to it and tapped a few times. Stasrted the car and bingo, the filler neck is bubbling. Man I wonder how long this has been going on. The car felt sluggish when warm. So I hope this solves that. Ok next thing Psykostevo, whats a good pump to replace this? Thank you for saving my car!!!
Old Aug 21, 2008 | 07:37 PM
  #167
rrutter81's Avatar
actually thats hatrick's hammer-mod
Old Aug 21, 2008 | 07:39 PM
  #168
jasz71's Avatar
Oh snap VERY sorry for the miscomunication!!!!
1). Thank you Psykostevo for alerting us!!!
2). hatrick's hammer-mod
Old Aug 21, 2008 | 07:45 PM
  #169
bobby71189's Avatar
nvm mine works. thanx for the look out tho
Old Aug 21, 2008 | 08:10 PM
  #170
joe118969's Avatar
I looked at my car, with the car cold there was very little coolant, I'd fill it a little while running, tap it with a hammer, don't know if tapping the thick aluminum casting is the right place to tap, and it seems like for a closed system it can keep drinking coolant with no end in sight weird?
NVM: found plastic side of casing after hitting it with a hammer it seemed to keep its level it was foamy. If the brushes are "soft" why isn't there one with harder brushes or a brushless motor?
Old Aug 21, 2008 | 08:27 PM
  #171
ItalianJoe1's Avatar
How do you turn them on via HPT?
Old Aug 21, 2008 | 08:29 PM
  #172
R&C_rallySS's Avatar
Thanks for the warning. I must say, I have never heard this. I checked mine right away and I have 0 problems.
Old Aug 21, 2008 | 09:21 PM
  #173
Doc's Avatar
Doc
while using the scanner, I'll get better directions when I get home tomorrow.
Old Aug 21, 2008 | 09:26 PM
  #174
Well I know that, but I was told that you can change something so they always come on when the key is in acc. I know how to turn them on manually while the scanner is hooked up.
Old Aug 21, 2008 | 09:31 PM
  #175
Doc's Avatar
Doc
I think the car has to be started and a certain amount of time elapse before it comes on.
