LSJ Intake Manifold is the Problem....ARE YOU SURE?
sorry i slept in so much guys i didnt expect this to blow up so much in the morning but u east coast time guys are all over it....and yes im speaking of a k20a2 engine
for those saying high compression and better IM design i think ur false. i can kinda give u the higher compression because u know the honda engine does have higher compression, but how come no one does that with the m62? if it has proven on another engine that its possible....take ur lsj apart, run less boost and higher compression and make more safer reliable power then?
with the cooling mods out for the lsj there is no reason why it cannot destroy a k20a2 in all aspects, but it doesnt.
again against popular belief im not here to hate on the lsj, i would like to see more come from it!
and for those that say IM heres a picture of a intake manifold with the 2 laminova cores and what represents the supercharger has a yellow tape across it. pretty similar to the lsj IMO...air comes in....gets jammed down thru the laminovas then forced back upwards into the head....
It may not look like it... but it flows 30% higher than the LSJ manifold.
Besides that... it is indeed; compression, head and cams.
If you take away those as factors, all your left with is a block and pistons... and consider that the K20a2 shares the same internal specs (86x86) as the LSJ.
Atlanta = midnight club in RL.
Trust me, it isnt pretty when you see those k20 bastards twincharging and laughing at your domestic ass.....
then again they laugh at bolt on vettes too. Fricken ridiculous.
I know some places in Texas are the same way.
http://www.theoldone.com/archive/
talks LOTS about head design and such. Runs a M62 on a civic with a HIGH compression ratio. Very interesting site.
after my research in my opinion i would stay stock pulley, up compression, get head work done, try those gmr cams and run a **** load of cooling mods...
how do u know it flows 30% more than a lsj intake manifold? and i understand its compression head and cams...thats why i made this thread because everyone thinks the intake manifold is gonna be there savior when it really doesnt have much to do with it.
Beyond that... getting the head to the point of a K20 head is next to impossible, simply because of the flow pattern. LSJ = sharp 90... K20 = gradual sloping curve
i may have had the wrong thoughts about u
its a one off manifold...lol...
That one flows down, straight into the cores, makes one turn, and into the motor.
I think we know what flows better.... flow turns are horrible for losses.
sig better work this time...
ok good, anyway even if you improved the design of the IM and gave it a colder denser charge you still have flow to play with. Compressed air heats up more, and that lies with headwork. You can even see the difference when you put on a free flowing exhaust as it drop 1-2 psi.
I'd go more for a combination...
As previously stated... CSS goes in cycles... head, cams, IM, etc.
Everyone is looking for one thing.... but it's not one thing... it's a combination of a bunch of things.
So far we have solutions for the top end (head, cams), and the down stream (exhaust)... but nothing for the up stream (IM)... I think that's the next step.
