LSJ Intake Manifold is the Problem....ARE YOU SURE?
Old Oct 29, 2008 | 05:55 PM
  #101
brandon2.2's Avatar
with 10:1 compression, cam, and stage 3 GM pulley, the LSJ will make a hair over 300hp, there is a lot of other work that can be done too, but the M62 sure can support or make over 300
its not the intake manifold
GM did all of this in there LSJ build book and its on CED.com, not sure why this is such a big argument, it can clearly be done and there is a "HOW TO" from GM
when my SC build is done, I'll show you
Old Oct 29, 2008 | 05:57 PM
  #102
Omega_5's Avatar
Originally Posted by Raven SS
no one has really provided a better cam IMO...and no one has provided a valuable port job that works..just cuz u port the **** out of the engine doesnt mean it works. when it comes to most race set ups on a K20 that is staying N/A they dont even touch the ports because they have the best set up for it stock.
As far as the cams... although re-grind, the 272's and GMR's both seem pretty promising, with any amount of patience.
As far as the head... I'm all for custom... but some companies 'claim' incredible gains off their port job... others are more reasonable... but none the less, it's an improvement of some kind.
The sad thing, though, is that I have yet to see a head with a port job optimized for an SC motor.
Old Oct 29, 2008 | 06:03 PM
  #103
ColeJJones's Avatar
Bannned
i will post dyno numbers before and after the head. we shall see what m2race can do
Old Oct 29, 2008 | 06:09 PM
  #104
elecblue06's Avatar
huh let me know how it turns out.. i was thinking about using them down the line since they're close to me
Old Oct 29, 2008 | 06:40 PM
  #105
ColeJJones's Avatar
Bannned
will do
Old Oct 29, 2008 | 08:37 PM
  #106
leviticus88's Avatar
umm... the honda motor your talking about has a higher compression ratio and a better flowing head...
Old Oct 29, 2008 | 08:38 PM
  #107
ColeJJones's Avatar
Bannned
way to be on top of things
Old Oct 29, 2008 | 08:46 PM
  #108
Lol, upps But its the truth
/End thread
Old Oct 30, 2008 | 12:11 AM
  #109
theneelster's Avatar
Originally Posted by freakta
im doing a custom air to air setup, got most of the parts but just waiting for more info to leak out so i know what problems could arise and what fixes were made
On a roots blower? That doesn't really make a whole lot of sense. Your temps will be higher vs. the stock manifold (presumably) and the routing wouldn't be direct (blower-->pipe-->intercooler-->pipe-->manifold vs. blower-->manifold). If you use the stock manifold it will still be a bottleneck.
If you use a centrifugal then it makes more sense but not really because a centrifugal doesn't heat up like a turbo because it's nowhere near the exhaust (you could probably get away with using the stock i/c system)
Old Oct 30, 2008 | 12:33 AM
  #110
Sharkey's Avatar
a risk you have with an air to air setup on a roots is by having the throttle body still bolted to the blower. if a charge pipe was to leak you will run rich (losing air passed the maf) or if i pipe blows off you have no throttle controll, its wide open. if you put the throttle body on the manifold after the blower, be sure to run a blow off valve as you dont just have pressure build up for a second like a turbo, it compresses air all the time.
Old Oct 30, 2008 | 10:22 AM
  #111
freakta's Avatar
no way my temps will be higher. im betting i could get rid of my laminovas all together gut my intake manifold and run it straight through and get lower temps.
it will go more like blower-intakemanifold-pipe-intercooler-pipe-intakemanifold-engine, the stock intake manifold will be just a shell of its original self and will not be much of a problem, im still trying to figure out what to do about making the runners longer and not hurting flow. thats a challenge
Old Oct 30, 2008 | 10:28 AM
  #112
Omega_5's Avatar
Runners are not possible with the stock shell. There just isn't enough room to do anything beneficial.
Old Oct 31, 2008 | 11:10 AM
  #113
Speedytec's Avatar
If you do some research on engine design, you'll find that the inlet (runner) design has a big impact on the engine's breathing behaviour. (Off course head, cams and exhaust do too.)
In an NA application it is much more important, but the principles on proper runner design are the same for NA or FI applications.
(I think that idling and low end behaviour of more agressive cams can be improved (a lot) with some proper runners in the LSJ's inlet tract.)
Do the turbo guys not have some comparison data on a turbo set-up with stock (gutted) LSJ manifold vs. the Hahn manifold with runners? That would give us some clues...
Old Oct 31, 2008 | 11:23 AM
  #114
ebristol's Avatar
The stock LSJ IM is not the problem.
Old Oct 31, 2008 | 11:26 AM
  #115
Omega_5's Avatar
... I'm just gonna re-post this... in case some people missed it.
Originally Posted by Omega_5
I'd go more for a combination...
Everyone is looking for one thing.... but it's not one thing... it's a combination of a bunch of things.
Old Oct 31, 2008 | 11:41 AM
  #116
PhantomSS's Avatar
yea but if you open up that head and leave stock exhaust, you didnt really go after the bigger culprit.
Old Oct 31, 2008 | 11:44 AM
  #117
Omega_5's Avatar
Yeah... on a bone stock motor (OEM), it's useless.
I'm referring to the average modded LSJ here; 2.7-2.9" pulley, intake, exhaust.
There are decent gains with each mod alone; head work, cams, IM.... but together, I think we will solve the 'problem' everyone is looking for.
Old Oct 31, 2008 | 11:46 AM
  #118
PhantomSS's Avatar
im actually more curious what people's gains are with headwork. That will determine my next step as far as IM.
Old Oct 31, 2008 | 11:49 AM
  #119
Omega_5's Avatar
Rebel did some test;
https://www.cobaltss.net/forums/show...el+ported+head
I've heard from some other vendors that they might be on the high side... but it gives an idea.
Old Oct 31, 2008 | 11:58 AM
  #120
PhantomSS's Avatar
i meant /w headwork done already,
test the new IMs. Otherwise its kinda like doing headwork with 1 inch exhaust. Its not really showing what it does.
Old Oct 31, 2008 | 12:01 PM
  #121
Omega_5's Avatar
Oh... no... not yet.
I'll probably take some data before and after the head swap, though.
Old Oct 31, 2008 | 12:02 PM
  #122
PhantomSS's Avatar
I think we would be in for a suprise.
Old Oct 31, 2008 | 12:09 PM
  #123
Omega_5's Avatar
I'll be putting the GMR cams shortly after, as well.
I think all 3, combined with my new 3" exhaust will have good results. Especially since I'm flow tuning each bolt-on component to match the head.
Old Oct 31, 2008 | 12:10 PM
  #124
PhantomSS's Avatar
definitley need to see a before and after with the IM then. That will speak mountains.
Old Oct 31, 2008 | 02:17 PM
  #125
Raven SS's Avatar
might be surprised with the gmr cams. heard someone had a huge problem with them
